#61 |
![]() Join Date: Nov 2010
timings good it ended up not holding idle because iacv hose wasnt hooked up to the intercooler -___- well got it to hold idle just need to get the o2 sensor and some other little things and car will be ready to drive
@lild415
#62 |
Good to hear. Well done.
Mishimoto Automotive |
#63 |
thanks ^__^ well i wired up my bee*r and safc neo. i started the car and it wouldnt keep idle. i just found that the line that hooks from pcv valve to the intake manifold -__-
@lild415
#65 |
haha yeah mark
![]() well i need your guys help. my tach isnt reading on my cluster but the speedo on the HUD cluster is giving the speed as the revs. so when it was idling the HUD was reading 8mph instead of the 800 rpms. the wires arent switch on the dash connector. any ideas?
@lild415
#66 |
ok well i just figured out why the motor wouldnt hold idle. the bottom of my freddy intake manifold wasnt completely sealed so i fixed that and now it idles finally
![]() well heres a video of me testing my bee*r since i got it to idle edit: well went to make sure the car would still idle and it wont anymore it seams to have another vacuum leak i can hear it but cant find where its coming from. ive had about 4 different vacuum leaks. i really hope this is the last one
@lild415
#67 | |
#70 | ||
thanks! I'm trying. talked to Dan at Part Shop Max and he said my rear drop knuckles wont be in until january so I'm trying to fix all the motor problems and get my interior all ready so i can put the knuckles on when they get here and just drive
@lild415
#72 |
bomex rear valance sold them to mel (ZAR) i think thats his zilvia name. i was told that no one had it in northern california possibly all of california
@lild415
#75 |
well i found a new vacuum leak and fixed it yesterday. car held idle today when i tested it but shot a decent sized puff of smoke so i turned the car off. i let it sit for a little while to try and figure out why the smoke thing happened. as i was cranking it it locked up -___- havent figured out why it did that yet but i was researching and it looks like its something to do with a bad injector
luckily i have a extra set of stock injectors in my possession.
@lild415
#76 |
so i took off the fuel rail to try and fix the motor problem.
![]() also hooked up the driveshaft bolted up the tranny added tranny fluid and found out i had 3 of 4 subframe nuts stripped already -___- so when i get my exhaust done im going to see if they will help me with the stripped nuts.
@lild415
#78 | |
![]() Join Date: Aug 2009
Trader Rating: (55)
![]() Feedback Score: 55 reviews
#79 |
yeah. i had everything organized and little things kept popping up then the injector problem. almost everything else is done just waiting on my rear knuckles and then i can drive the car around for the first time in 16 months
@lild415
#81 |
Trader Rating: (55)
aha yeah i know how you feel, for me it's been technically 14months but I had it out driving for one month in april so since then it's been 8months should be out and completed in another 2. You decide what color your going to paint it?
#82 |
i think im plastidipping (flame me if you so choose) it white for a few months just so i can daily it and not grab alot of attention then i want to either go back to the original dark green or midnight purple when i have money.
@lild415
#83 | |
Trader Rating: (55)
#84 |
thanks! i will ive been really leaning towards the green we will see when i get money. gotta buy my new wing, front wheels and front knuckles still -__-
@lild415
#85 |
Trader Rating: (55)
word. no 326 wing no more? and talk to Driven08 about knuckles or D.Adams on here get you a good deal. Unless your trying to buy the PSM drop knuckles then save up, same for wheels, equips are one of my favs.
#86 |
yep got rid of 326 i felt like it didnt fit my car right. im getting pbm because i have the front lca's already and ive heard really good things about them. for wheels i havent decided if i want to get a pair of equips for the front or a full set of something else. we will see when i get some more money to play around with. for now its get the car reg'd and smogged so i can drive it around
@lild415
#87 |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
You've definitely stuck with it through multiple problems. I recently had a similar experience with bad gaskets, leaks, bad IACV, etc. Just one thing after the other. It gets frustrating!
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
#88 | |
Trader Rating: (55)
That's why its always good to go over/replace all gaskets, before swapping in the motor. |
#89 | |
@lild415
#90 |
so i found a hole in my return line to the fuel tank which was causing my car to leak alot of gas onto the ground, hooked up my power steering finally, planning on bleeding my clutch and brakes within the next couple of days. all that i have left to get my car driving is get a front bash bash bar made, get the rear knuckles and then rear z rotors. hopefully in january ill be on the streets driving and getting ready for some track events
@lild415
