Guest
Posts: n/a
Alright, for starters my car has 75000 miles on it and it is a 96 and i have a prob with it. One, sometimes it will go really fast (low 15s) in the 1/4 and then all of a sudden go to crappy 17's tops. What is wrong with my car? Do i need to tune it up? I already put a new dist. rotor, plugs, wires 300zx fuel filter, and just change the oil. Any other ideas for tune-up?
![]() Join Date: Jul 2001
Is it the car or is it the person driving the car thats getting the quarter mile times. 17's are only a crappy launch away from the 15's. What do you feel is wrong with the car? How doe's it feel when it's not running right?
Guest
Posts: n/a
Sometimes it will pull all the way through the whole RPM range with smooth acceleration signing off at about 5500-6000. But most of the time the acceleration will be bad and then pick up, almost like V-Tec or something, at 4000, pull like it should for about 500-1000 rpm then become erratic till finally about 5750-6000 RPM where most of the time it won't even want to get to redline. Weird, huh? I have no clue what it could be but the check engine light came on and said it had a random misfire.
Guest
Posts: n/a
come on guys?!?!?!!?
I heard these plugs have their problems, should i get the reg NGK's? Also, is an ignition rotor an ignition rotor or does $6 (the price of mine) sound too cheap? How do i check the fuel injectors? Also, how much does a factory manual cost? Could it need a new timing chain?
