Old 04-15-2019, 11:12 PM   #1
doridoridori
doridoridori is an unknown quantity at this point
turbo coolant line crust
quick question, so i been taking the car to drift events finally. Usually after an event i'll get the car on the lift, look everything over make sure everything is in place. I noticed on the coolant feed line/return line going into/out of the turbo it almost looks like some crust/dried up coolant. If memory serves me right im 99% sure i teflon'd the threads to those lines in particular. Is this something that happens over time? maybe due to the heat the turbo produces or do the fittings possibly get loose over time?
thinking about re-bleeding the coolant. The car doesn't overheat or anything like that but that did stick out to me.
any help would be much appreciated
setup is:
Redtop SR20
S14 T28
nothing crazy
If I had a dollar for every pet named "nismo" by a nissan owner Id be rich
doridoridori is offline   Reply With Quote
Old 04-16-2019, 05:14 AM   #2
s13silvia123
s13silvia123's Avatar
it's something that happens over time. you're suppose to replace them every now and then because they deteriorate over time.
Old 04-16-2019, 07:21 AM   #3
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
FYI the coolant feed and return are straight cut threads, meaning Teflon Tape should NOT be used, they require a crush washer. Teflon is only for Tapered Threads
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 04-16-2019, 11:13 AM   #4
doridoridori
gotcha, so just replace the lines and should be fine?
Old 04-16-2019, 11:14 AM   #5
doridoridori
thanks for the info, cant remember if i did or didnt its been a while
