![]() Join Date: Jun 2010
Godspeed Intake Manifold?
Anyone have experience with these? Im looking to get one for my S13 SR20DET. What is the casting quality like? How was the install overall? Should I just spend a few more bucks and get a less crappy ISIS? I'm aware that these knockoff manifolds sometimes require the casting and threads be cleaned up. Thanks!
edit: I would most likely have the throttle body, cylinder head and possibly IACV flanges planed at a machine shop. |
![]() Join Date: Jan 2006
I'm sure it will work fine if you machine the flange flat, clean up all the casting and empty the shavings/chinese sand/whatever the hell these things are made of. It might even flow as well as an OEM part at that point.
![]() Join Date: Jul 2007
Trader Rating: (106)
Is the 240sx "community" REALLY degrading to the point where we try to differentiate which one is better between two pieces of shit???
Godspeed=ISIS=Megan=ANY other bottom line knockoff shit... Not one is any better than the other. |
#4 | |
People buy these and have been running them for years. They work, how well? Who knows. The quality is hit or miss, but if your willing to spend the money to have it cleaned up, then you'll probably correct most of the issues. With that being said, the final total after having it machined/cleaned up is probably pretty close or in excess of the real part. |
![]() Join Date: Apr 2006
I thought there were only two doors....
1) Entrance 2) Exit and then a bunch of boxes in various palettes going to the various vendors in the US that sell that cheap shit... Just saying... |
![]() Join Date: Dec 2011
OMG I just got my intake manifold today. Glad to see this thread. Best product ive ever seen. Best product to come from jdm. So awesome! Im gonna order godspeed suspension.
#11 | |
not true at all times, if you mean the more expensive the product the better quality it is. how often does a major brand name confer a higher price just because said brand name? more often than most people suspect. not that i am giving an opinion on this intake manifold as i simply do not know.
66 Plymouth Satellite, 96 Nissan 240sx, 03 Harley Sportster. Toys! |
solution..... make your own intake manifold. you will know the quality, and its not any more expensive then your "brand name" manifolds.... screw "JDM" ...my manifolds are both american made!...lol
#16 | |
![]() Join Date: Sep 2008
...ugh.... |
#17 |
#19 | |
![]() Join Date: Apr 2011
#21 | |
Lots of replys, none with first hand experience.
Not sure what you mean by this, an OEM manifold or an aftermarket manifold built to OEM standards? Quote:
The GReddy manifold is $900, knockoffs are under $200. Sure, the genuine part will have a better finish, but will it provide 4 times the HP gains? I have a die grinder and dremel, the machine work would be $50-100. I did search, there is nothing about the Godspeed manifold, there is a thread about the ISIS and it states that it isn't too bad. This is true, a friend of mine had the rod end of his brand new PBM LCA's fall apart. Thank you for witholding an opinion without any first hand experience. |
#22 |
Why do people pay for brands such as ISIS or Godspeed which are just middlemen for Ebay parts when one can buy the exact same part on Ebay for cheaper and without any brand name?
#23 | |
I'm not in anyway saying "buy Brand-XYZ", but I've seen enough parts and know enough people working with said parts that there is a difference between a ISIS FMIC and a CRX FMIC and a "no-name eBay" FMIC. There is a sliding scale of material control and build quality. So while a Godspeed FMIC is inferior to a Blitz FMIC in material, fit and finish... the "eBay" FMIC will be inferior to a Godspeed in material, fit and finish. As the saying goes "you often get what you pay for". The other benefit of buying a ISIS part is you are typically buying them from Enjuku, who is a long standing reputable company. Buy from eBay is bad for two reasons, A. you are support eBay and their predatory business practices as well as fucking paypal. B. you never know who you are buying from and what the ACTUAL parts look like. I think we've all be screwed over on eBay at one time. So it's only natural to pay the extra 25% for an ISIS part over the eBay one because it should be to "isis spec" and if it's not, Enjuku will make it right. |
#24 |
So basically, they are the exact same parts from the exact same place, except brands such as ISIS or Godspeed make sure to pick out ones that turned out decently, while the 'no brand' ones that end up on Ebay have a larger chance of being a hit or a miss?
At least that is how I always hoped it works, so they would at least have some justification for charging a bit more, instead of just preying on ignorant people. Because I have held ISIS parts and 'Ebay' parts that were completely identical, down to the stampings and spots in the material that made it obvious they were made in the same place. |
#25 | ||
![]() Join Date: Aug 2011
On my current 240sx, I do not use those lower control arms because I would like to drive on the street sometimes. A lot of the stock suspension is designed to handle daily road abuse where these aftermarket arms, which still strong, doesn't hold up well against train tracks. Also paired with energy suspension bushings that binds and you're asking for world of trouble. |
#26 | ||||
You are a cheap fuck. Smart people dont value a part based on how much it costs vs how much HP you make. A McLaren F1 isnt 100,000 times faster than a 240SX. A 20" dick does not give a girl double the pleasure of a fucking 10" dick. Seriously, how fucking stupid can you be. Here are the reasons why you should spend $900: 1) Because Greddy designed and manufactured that component 2) Because its high quality and not flawed 3) Because its the right thing to do In the end, it doesnt matter because you suffer from CFS (cheap fuck syndrome) and you're going to support some shitty slave-labor company, which in the end will probably result in motor failure which will cost you much, much more in the long run. Dont worry, you wont be able to figure out which part failed on you because all of the parts on your jank car are all shitty. You could say its a collaboration of shitty parts, resulting in a piece of shit car. Quote:
Because Enjuku gives you free stickers with your purchase. ![]() Ah yes, I always wanted to look like a fucking douchebag. |
#27 |
Greddy "Designed" and "Engineered" their catch cans too. So i should buy those empty boxes of shit with the pretty logo that are not a true catch can because they designed, engineered, and made them.
I hope a bad casting in the ebay can doesnt blow the welds on the intake manifold. ![]() |
#28 | |||
Aaron is a master mechanic? Whoop-De-Fucking doo. Does that mean he has hooked up all the SR20DET intakes and rocked the flow-bench to see what flows best? Has he done a tooling and quality sustainment study of the manufacturing process of the Chinese casters that make the knock-off intakes? Does have GD&T data on an impact study for the parts and their assemblies? No, I bet he's seen some shitty made parts and some good made parts. Obviously good made parts are better. Quote:
That goes without saying. 3rd party stock parts are utterly garbage built to the lowest bid. You also have to remember that the 3rd party companies do not have any access to original drawing, specs or testing requirements. I learned that back in high school working on cars. Cheap metal, cheap fasteners, cheap rubbers, terrible dimensions and tolerances. |
#29 | |
Next time you have the chance, you should take photos. My personal experience is more with the FMIC parts. I've personally seen plenty of eBay and ISIS FMICs, they are absolutely not the same, nor are the pipes. There is also a big difference in various ebay FMIC. |
#30 |
![]() Join Date: Aug 2013
This is what's wrong people these days is nobody takes pride in their car anymore.
People go by Price over pride now a days. Sure we all know everyone has a different level of expendable income to dump in their car but spending more of a quality name brand item that you know isn't going to fail on you and the pride of having a legit part is all worth it. Ikea Formula intake plenum (3k) > FAILSPEED(ching chong china special) 150-500 ![]() |
