![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 6 reviews
S13 Sr Tranny Wiring
I recently purchased the wiring tranny from wiring specialties for the S13 Sr20det. I'm having issues with the last part. I got a plug leftover near the fuse box, so I'm a little confused.. I don't see a female connector for the last part except the brown plug, but the female has different grooves for the grey plug. Any ideas?
http://site.wiringspecialties.com/cl...ionHarness.pdf Last edited by aznxkrnxboi; 01-04-2012 at 12:28 AM.. |
I would like to show my appreciation to you just for rescuing me from this particular matter. Right after searching throughout the online world and seeing things which were not pleasant, I assumed my life was over. Living without the presence of solutions to the issues you’ve solved by means of this guide is a critical case, as well as ones which might have in a wrong way damaged my career if I hadn’t come across the blog. The skills and kindness in taking care of a lot of things was important. I am not sure what I would’ve done if I hadn’t discovered such stuff like this. I can at this point relish my future. Thanks very much for your professional and result oriented guide. I won’t think twice to recommend the website to any individual who needs guidelines on this subject matter
my new website : http://www.baywindowcurtainsshop.info |
Lol just bought a wiring harness from wiring specialists for my sr20/z
i found out that i don't even need the tranny harness peeps just directly connect alternator, speedo, tranny, battery, etc etc How is the harness it looks clean dude, yury has nice work |
it's clean looking, I'm going to take pictures once everything is done. I'll post it on here for a tutorial on tranny and the engine harness. For future reference people will be able to install without any hassle.
http://site.wiringspecialties.com/Wh...ionHarness.pdf
For Auto to manual conversions, connect the two Grey extension plugs to the firewall-side of the fuse box, where 4 chassis plugs are located. For 5-speed swaps, disconnect the auto extension wiring from the harness, remove the 3-wire connector and tape up the remaining wires. I hope this helps with the issue
Visit our Website - Check out our Blog - Like us on Facebook - Follow us on Instagram |
