Old 07-10-2012, 11:29 PM   #1
Acreus
Acreus's Avatar
Acreus is an unknown quantity at this point
CA VQ35HR swap into s14
So i recently picked up a vq35hr motor and transmission complete including cluster, ecu with key fob and wire harness for the entire car. What looks like three main wire harness'.
Bought the entire set up for $1500
only issue is... it automatic -___-
oh well... im in the process of picking up a new 6spd transmission
The Plan...
Drop it into my s14 and drift the crap out if it!
Im Clearing out alot of the wiring that i dont need, and plugging in the stuff i do need.
THINGS IM MISSING:
steering pump (purchased, thanks to Erin @ Nissan Unlimited)
main belt (purchased)
MAF's (purchased)
Custom Mounts (using stock vq mounts)
Drive shaft
custom shifter bracket
one rad hose
and just for kicks, im gonna hook up the AC!
so throw in AC condenser
clutch
Flywheel (purchased, thanks to Erin @ Nissan Unlimited)
Dash harness (purchased, thanks to Erin @ Nissan Unlimited)
gas pedal w/pigtail (purchased)
will post more pics soon,
Acreus is offline   Reply With Quote
Old 07-16-2012, 09:31 AM   #2
WhiteGLX
WhiteGLX's Avatar
WhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to all
Send a message via AIM to WhiteGLX Send a message via Yahoo to WhiteGLX
This swap takes a bit of creativity into a LHD S-chassis. One guy did a RHD conversion so the starter would clear the steering box, i went another route by relocating the starter solenoid to the engine mount and then i could get the motor sitting lower in the engine bay. Wiring is the next serious challenge, if you disable the NATS then you need minimal wiring from the 350Z chassis. I can give some other pointers, but none of it is just drop in and go, everything is custom or trial and error.
***NASA HPDE Instructor***
WhiteGLX is offline   Reply With Quote
Old 07-29-2012, 12:08 PM   #3
Acreus
Acreus's Avatar
Yeah, i ve done so much research on this swap. I'm actually going to have Zfever out in Florida do my wiring and the ecu flash. It's pricy, but i dont want to deal with that head ache of matching all the wires lol. As far as the custom fab work, ill be doing that all my self. I know the starter gets in the way, so i might make a new bracket to move it to the passenger side. Theres alot of things i need to get ready before i pull out my old KA and start plugging away at this motor.
Thanks for the tips, ill keep in touch post here when i get something new. so far, im still recovering from the motor purchase. I also just got back from vacation, so im pretty much spent for now.
Old 07-29-2012, 12:10 PM   #4
Acreus
Acreus's Avatar
Do you have any pics of your starter?
Old 07-29-2012, 12:14 PM   #5
KansaiDrifter
KansaiDrifter's Avatar
KansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud of
They're a fun swap, I did my DE engine since I'm going turbo anyhow but NA the rev up's or HR's are awesome. I had a Z fever harness and reflash, same boat was expensive but was worth it for not having a headache. Fired everytime, was very reliable.
KansaiDrifter is offline   Reply With Quote
Old 07-29-2012, 01:47 PM   #6
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
Good luck with build
#0191 "Lin'da" 2AMR>2AMR>
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 07-29-2012, 02:04 PM   #7
rik boellen
rik boellen is an unknown quantity at this point
good luck.
i'm doing a de swap at the moment
as for the starter i saw the 2 others dealing with this .
but if you mount a vq35de gearbox i think you can do the starter on the pas side?
is there someone who can tel me this could"t be done??
regards
rik
rik boellen is offline   Reply With Quote
Old 07-29-2012, 08:12 PM   #8
Guilty1s
Guilty1s is an unknown quantity at this point
The hr only has starter on one side unlike the DEs
If you need a 350z gas pedal, let me know. I have one. I think I wanted 70 for it.
Doing a de swap at the moment.
Guilty1s is offline   Reply With Quote
Old 07-29-2012, 10:13 PM   #9
Nismo11
Nismo11 is an unknown quantity at this point
Good luck with the build!
Nismo11 is offline   Reply With Quote
Old 08-03-2012, 06:03 AM   #10
WhiteGLX
WhiteGLX's Avatar
hopefully this helps. For the speedo and tach to work you will next an external setup, Tach that can use an autometer signal generator off a coilpack, and for the speedo you need to use something that utilizes a magnetic pickup for a wheel speed sensor. My solution was not cheap but it looks good for a DD.
Old 08-03-2012, 05:00 PM   #11
Acreus
Acreus's Avatar
Starter looks amazing! thanks for the great ideas!
And WOW, Love the stacks cluster. The company "Z fever" said they can have everything wired up so that all i have to do is worry about finding an input for the speedo. but Q45 diff with speedo sensor should fix that.
Who's motor mounts did you end up using?
Bc When i talked to the guys at Z fever in florida, they said that the engine has to be raised on one side about an inch to clear the steering rack, and the MicKinney mounts are for the vq35de.
Old 08-03-2012, 05:01 PM   #12
Acreus
Acreus's Avatar
I do need that 350 gas pedal. does it come with the pig tails?
Ill, pm you
Old 08-06-2012, 08:19 AM   #13
WhiteGLX
WhiteGLX's Avatar
the motor does not need to be raised on one side, it just needs to be properly aligned. I used McKinney Motormounts for a VQ35DE, and added 1/2" spacers to teh LH engine mount, and 1/4" spacer to the RH engine mount, this pushed the mounts out and makes the engine sit a little higher, any lower really and it would be sitting ont he cross member anyways. The spacers push the engine to one side a little bit while keeping it very sturdily mounted and level. I still had to relocate the starter solenoid to clear the steering box, this contraption was the biggest challenge aside from the wiring to get this project completed. I will have the entire setup mounted again into my S14 in a month or two depending on time and such, but might have some better upto date pictures by then, not much will change though besides the addition of AC and PS to the engine.
Old 08-10-2012, 10:31 AM   #14
nd240sx3
nd240sx3's Avatar
nd240sx3 is a well-known jackass
Send a message via AIM to nd240sx3
damn i need this starter setup so i can put the vq in a very asap
nd240sx3 is offline   Reply With Quote
Old 08-26-2012, 03:38 PM   #15
mpact1981
mpact1981's Avatar
mpact1981 is an unknown quantity at this point
where did you find that engine with all accessories for only $1500??? cheapest i find HR's for is like $3k and that's without accessories, trans, ecu, etc...
mpact1981 is offline   Reply With Quote
Old 08-29-2012, 08:34 PM   #16
Acreus
Acreus's Avatar
It came from a guy who fixes and sells auctioned cars. He decided to sell off the rear quarter panels bc some one offered alot of money for them, and part out the rest of the car. He pulled out all the wires uncut, ecu, steering column, transmission, and even key fob etc.... He just wanted it out of his shop. I got really lucky finding it and picked up the next day when he posted it.
Old 08-30-2012, 03:28 AM   #17
mpact1981
mpact1981's Avatar
That was lucky. I've been keeping an eye on the copart website. They auction wrecked cars. Once I find a decent wrecked Z (HR) around NC, I'm going to jump on it also. Hopefully I can make some of the money back by parting out the car like he did and possibly get the parts I need for the swap practically free. I just have to be patient I guess...
Any updates on your swap yet?
Old 09-02-2012, 12:35 AM   #18
BoostWanted
BoostWanted is an unknown quantity at this point
I'm glad you're actually doing something with the engine! Let me get that S15 front end!
BoostWanted is offline   Reply With Quote
Old 09-29-2012, 01:55 PM   #19
Acreus
Acreus's Avatar
Picked up a 6 speed transmission from a 2010 370z. Alright, I'm getting back into this build. I had set it aside so i can save up some $$$ and i got the ball rolling again on this thing.
It didn't come with a shifter but luckily it came with the shifter bracket. There where a few other ones i was looking at that didnt come with this important piece. as you can see, i marked the lines where i need to cut to make it line up with the shifter hole in the 240.
Old 09-29-2012, 02:13 PM   #20
Acreus
Acreus's Avatar
Picked up a pretty fresh Jim Wolf intake system with the MAF sensor that i needed. This thing is gonna roar.
and of course i needed to get the serpentine belt, so i ordered one of those too.
I've been trying to get my hands on a power steering pump at a decent price. for some stupid reason these things run $300+ - ___- anyone got any ideas? ive been keeping my eyes peeled for a used one, so if anyone just so happens to have one sitting around ill buy it. oh, i think it has to be for the VQ35HR and not the DE.
More picks coming soon!
Also, if you guys are curious what i plan to do with the stock KA, I'm not sure yet.
I have a coupe with cage and no motor that i might put it in. idk, lmk what you guys think!
Old 09-29-2012, 02:18 PM   #21
Acreus
Acreus's Avatar
A close up
Old 09-29-2012, 02:32 PM   #22
Synergy
Synergy is an unknown quantity at this point
1-800-835-4645 ext 200
Butler auto parts has 2 PS pumps in stock 85$ ea.
Synergy is offline   Reply With Quote
Old 09-29-2012, 02:34 PM   #23
Synergy
Just in case you were doing some sort of pulley setup 1-800-385-0938 They have a PS pump with a bent pulley on it. 20$.
Old 09-29-2012, 02:38 PM   #24
mpact1981
mpact1981's Avatar
I was wondering if you had given up on this lol about two more months and ill be starting mine.
Old 09-29-2012, 06:04 PM   #25
Lil_D
Lil_D is an unknown quantity at this point
i cant wait till this is done i want to tandem with you and drive it
Lil_D is offline   Reply With Quote
Old 09-30-2012, 03:06 PM   #26
Acreus
Acreus's Avatar
Haha, i never give up on my car lol. I've been aiming for this swap for quite some time now. So this is just a little bit of a side track from the actual swap, but if you guys wanna know, i haven't been sitting on my ass letting my car get no where. Always working on this thing lol. So lately I've been playing with one of the S15 bumpers i have. I got my inspirations from this...
Here I go!
I need to cut out the license plat mount and form a line across the bumper from there.
Then cut those top corner pieces bc ill be moving them up about two inches.
Zip tie it together...
Glue the pieces together with a really strong bumper adhesive, and then sand down the front.
Mount it on the car, and do some bondo work to match the lines.
Do the same to the other side...
Old 09-30-2012, 03:12 PM   #27
Acreus
Acreus's Avatar
Here's the bumper after i did a quick primer paint job. I'm gonna send the bumper to a shop to finish it up for me. I can shape things, but it isn't as perfect as i like it.
The comparison with the original bumper.
I'll be getting back to the swap very very soon.
Old 09-30-2012, 03:13 PM   #28
Acreus
Acreus's Avatar
Oh yeah! the Lip is a JDM integra lip. i really like the subtle OEM look with a little tweek.
Old 09-30-2012, 03:16 PM   #29
Acreus
Acreus's Avatar
Thats awesome! It's definitely not a simple swap. What VQ are you swapping in?
Old 09-30-2012, 04:49 PM   #30
mpact1981
mpact1981's Avatar
I'm going to test my skill and attempt to swap just about everything from an 07/08 Z into my s13 coupe. Similar to what the guy did with his dad in the previous thread. I have an 08 Nismo and I'm pretty familiar with VQ's in general after having wrecked my 06 twin turbo. I'm going to take my time with it though. Right now I have to get my s13 from my house in Louisiana to my house in North Carolina and I'm always keeping an eye on the copart website for a good deal on a wrecked Z nearby
vq swap
