Old 03-31-2009, 11:30 AM   #1
mjhockey155
mjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymoremjhockey155 is not welcome here anymore
Autocross Classification
I am going to an autocross event this weekend and I am having trouble deciding what class to enter. This will be my first time running so you could consider me a Novice.
Here are my mods done to my 93 coupe:
Exterior:
all stock except:
pignose lip
Interior:
All stock except:
Sound deadening removed
Gutted interior except: dash, door panels, fronts seats, center console, A pillar plastic, and interior lighting, manual seatbelts
Stitch welded chassis interior only
Removed rear speaker deck metal and rear seat supports
Engine:
Cold air intake
High Flow Cat
Cat Back Exhaust
Suspension:
All stock except:
Tokico Blues shocks and springs
poly front lca bushings
Boxed oem lca
spherical bearing tension rods
poly steering rack bushings
poly endlinks on front sway bar
Drivetrain:
R32 vsld diff
1 piece aluminum drive shaft
Inifniti J30 Axles
mjhockey155 is offline   Reply With Quote
Old 03-31-2009, 11:34 AM   #2
LongGrain
LongGrain's Avatar
i think you will be in either STS or STX
those tension rods might screw you over though, i know spherical bearingings automatically put you in a prepared class.
LongGrain is offline   Reply With Quote
Old 03-31-2009, 11:45 AM   #3
aznpoopy
aznpoopy's Avatar
aznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond repute
Send a message via AIM to aznpoopy
pretty sure the tension rods are going to bump you up to STX.
aznpoopy is offline   Reply With Quote
Old 03-31-2009, 11:49 AM   #4
MandTPhotography
MandTPhotography is an unknown quantity at this point
Yep, you'll be in STX if I'm not mistaken.
Enjoy your time in the Novice class though.
I'm in STS2 and it's so damn competitive.
MandTPhotography is offline   Reply With Quote
Old 03-31-2009, 11:55 AM   #5
VQMaxFan
VQMaxFan's Avatar
VQMaxFan is on a distinguished road
wont the gutted interior put you into SM?
VQMaxFan is offline   Reply With Quote
Old 03-31-2009, 11:59 AM   #6
silsx13
silsx13's Avatar
Trader Rating: (34)
silsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant future
Feedback Score: 34 reviews
Send a message via AIM to silsx13
s13
Depends on how the region handles it.
On the national level, a gutted interior would be looked upon more closely while if you're just doing regional events, it won't really matter that much.
Looking at the mods, it looks like you'd be in either STS or STX but I'm leaning more towards STX.
And tell them you want to also be classified as a novice since it is your first event out there.
Good luck and have fun this weekend.
Blog: http://hartapexlife.blogspot.com/
silsx13 is offline   Reply With Quote
Old 03-31-2009, 12:10 PM   #7
ASIA
ASIA has a spectacular aura aboutASIA has a spectacular aura aboutASIA has a spectacular aura aboutASIA has a spectacular aura aboutASIA has a spectacular aura aboutASIA has a spectacular aura about
Send a message via AIM to ASIA
I'm thinking DSP because of the gutted interior. If you put back the interior, you'll definitely be in STX.
ASIA is offline   Reply With Quote
Old 03-31-2009, 12:11 PM   #8
LongGrain
LongGrain's Avatar
i may be wrong but i was under the impression that STS and STX did not allow any spherical style bushings, you could upgrade to poly but had to keep it OEM style.
but you can always just leave out the fact they are spherical, just say you have adjustable tension rods. its not like they look under your car or anything.
i mean, if its your first time i'm sure you arent too worried about being put into a competitive class... just go out there and have fun.
Old 03-31-2009, 04:01 PM   #9
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
Don't you get bumped up to SM class when you gut your interior especially when you removed the rear speaker deck metal and rear seat supports? Doesn't it falls within the same lines as replacing factory metal hood and trunk lid w/ carbon fiber or fiberglass panels to save weight?
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 03-31-2009, 06:40 PM   #10
silsx13
silsx13's Avatar
Trader Rating: (34)
s13
Yep I agree. I don't think they'll make a big fuss about having just the adjustable tension rods BUT if you had more spherical ball stuff like the rear camber arms, toe-rods, etc. etc., then I'd say you should be in a higher class.
And, I stand corrected- STX DOES NOT allow spherical ball arms. I did however run in that class for awhile before realizing I couldn't....nobody said anything though because I wasn't that competitive to where I was blowing people away and placing top 3 consistently.
Other than that, go out there and have fun if it's your first time doing autocross! Worry about classification stuff later...
Old 03-31-2009, 07:24 PM   #11
S14DB
AFC #1
S14DB's Avatar
I got fucked hard with pillow ball mounts installed. It's best to feign ignorance when you are starting out.
Old 03-31-2009, 10:01 PM   #12
r-b-x
r-b-x is an unknown quantity at this point
i don't think even sm allows stitch welding. so.... d prepared? that's where you're allowed to go nuts on the chassis, but not allowed to swap engines.
but if you're starting out, it doesn't matter. it's only when you want to start getting a meaningful win (ie abiding by the rules everybody else plays with) then should you start worrying about proper mods and classification.
r-b-x is offline   Reply With Quote
Old 03-31-2009, 10:10 PM   #13
s13silvia123
s13silvia123's Avatar
sts but the last time i went its really up to what you want to be in. if youre a beginner go as one cause you'll be competing against people who would be better than you. unless you are competing.
