search with no result. J30 rear end help
Here is the deal, I bought a 5 lug rear subframe and has a J30 Diff. Guy said the Subframe was from a S14. It definitely has the J30 Rear Brake setup. You know the one with the drum e-brake. So here is my question:How do you get the e-brake to work? the cable mounts for it or off. Then the cable itself is too long. Is there a different cable to use or a way to bypass it? I have to get new calipers since mine did not have any. So would it be smarter to get S14 or 300ZX Calipers and then use my stock e-brake lines to hook that up? Also what all brakes will fit the J30 Setup?
I did search both current and archived, nothing really relates to my questions and or the questions were never answered. |
![]() Join Date: Dec 2002
I don't buy that you searched, but I'll be nice.
The entire brake setup bolts right up by swapping uprights, they're larger than the OE S14 calipers/rotors, the rotors are actually the same size as the Z32. The cables can be used if you build new brackets to accept and hold the cables or cut/splice the cables with the S14 parts and make new cables completely. Either way there's modification involved, but nothing major. Everything else is simply replacing OE parts.
So the Z uses the same kind of Drum E-brake as well? I did search I am sorry I did not have a lot of time to get through all the pages but I spent a good hour, I saw some how to about the ebrake cables, I also seen people that have put the J30 brakes on there but no discussion of the J30 e-brake issue, I could have been searching the wrong keywords, I do not know. I appreciate you being nice enough to fill me in rep points for you.
