Old 08-29-2008, 07:28 PM   #1
Enjin
Enjin's Avatar
Enjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enough
Send a message via AIM to Enjin Send a message via Yahoo to Enjin
how hot is necessary to burn out old bushings?
I am in the process of replacing my old 200k mile bushings with the rsr kit.
I have a propane torch. it is hot enough that it turns green, however, maybe my technique is wrong because I am not having any luck melting out the old bushings per instruction sheet.
anyone have any tips? or would I be better off just biting the financial bullet and spending about $250 taking all of my detached suspension arms over to a shop to have them replace them?
1991 Nissan 240sx
www.tractionoptional.com
Enjin is offline   Reply With Quote
Old 08-29-2008, 07:52 PM   #2
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
hammer it out as well and pry it
Old 08-29-2008, 08:00 PM   #3
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
Find the pyro kid down the street and he should have the necessary tools to burn those suckas!
Gasoline.
undesiredshoe is offline   Reply With Quote
Old 08-29-2008, 08:01 PM   #4
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
UNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond repute
Feedback Score: 40 reviews
Send a message via AIM to UNISA JECS
Map gas torch and appropriate size sockets and a hammer.
UNISA JECS is offline   Reply With Quote
Old 08-29-2008, 08:23 PM   #5
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
try torching metal surrounding the bushings and the inner metal ring, just get it really hot. and they eventually start to pop out on their own. you can just get the rest of the remains with a flat head screw driver and some more heat. a small wire brush helps as well.
louisdaboois is offline   Reply With Quote
Old 08-29-2008, 09:13 PM   #6
Enjin
Enjin's Avatar
ok cool. concerning the socket technique... how do I position it so that I can hammer it OUT, rather than INTO THE FLOOR?
maybe put it half on a table and half off? I don't really have a workshop, and no table with vice grip...
1991 Nissan 240sx
Old 08-29-2008, 09:32 PM   #7
louisdaboois
Trader Rating: (28)
you get a socket that fits around the outside edge of the bushing and another socket that'll catch the bushing when it falls. and simply beat the smaller socket until the bushing falls into the bigger socket.
Old 08-29-2008, 09:52 PM   #8
Enjin
Enjin's Avatar
solid advice, thanks.
1991 Nissan 240sx
Old 08-30-2008, 12:58 AM   #9
devnull
devnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymore
I've used things as small as a hand-held propane torch (the kind you use for soldering pipe), but a professional oxyacetylene setup makes things so much easier that it's laughable. I find that heating the bushing up from the outside burns the rubber away from the shell better, which makes cutting out the shell a lot easier.
With the little propane torch I had no choice but to burn the bushing from the middle, which still took way too much time and left me with a big mess while cutting the shells.
devnull is offline   Reply With Quote
Old 08-30-2008, 01:10 AM   #10
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
Harbor Freight has some relatively cheap bushing presses, $100 or so for the cheap one and mid $250 for the big mofo. They have some in between too.
Harbor Freight Tools - Quality Tools at the Lowest Prices
Not that that actually answers your original question.
ryguy is offline   Reply With Quote
Old 08-30-2008, 01:29 AM   #11
SexPanda
SexPanda's Avatar
When metal gets hot, it expands. You dont want the bearing to expand, so torch the metal around the bearings, and try to keep the bearing cool with oil or something.
Then take a BFH, beat away, say fuck it, and get a 2.2 stroker kit lol.
Old 08-30-2008, 02:52 AM   #12
180sx Fan
180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all
i have that harbour friehgt cheap press works good did my bushing install and a friends with it now.
sex panda hes talking about bushings not bearings.
Originally Posted by logik23 View Post
We all have small dicks, admit it, the difference is now I can compensate for it.
180sx Fan is offline   Reply With Quote
Old 08-30-2008, 01:25 PM   #13
Enjin
Enjin's Avatar
hahahaha I love BFH.
found a local guy to do it for $100 so I say f it, I still have a big propane torch just laying around :-P
1991 Nissan 240sx
Old 08-30-2008, 01:30 PM   #14
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Propane torch is fine, just let em burn!
We dont need no water let the motherfucker burn!
Seriously though lust let em burn untill the rubber starts oozing out of the bushing, then let em burn some more. The inner sleeve will literally just fall out on the ground. Then you just take a flathead screwdriver while it is still burning and scrape the leftover rubber out, a LONG screwdriver for god's sake I don't want you to burn the crap outta yourself! After that cut through the outer sleeve with a hacksaw and then knock the outer sleeve out with a punch and hammer. Don't be too worried about cutting into the arm slightly either, it won't hurt anything unless you cut like halfway through the thing.
racepar1 is offline   Reply With Quote
Old 08-30-2008, 03:35 PM   #15
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
propane or map will take forever for any decent size bushings.
i did my subframe with a cutting torch (acetylene/o2) and i had the whole job done in a couple hours.
aNskY is offline   Reply With Quote
Old 08-30-2008, 04:10 PM   #16
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Mapp gass is a better choice than propane for heating up the multi-links, its much quicker, but I do agree with aNskY about the subframe (acetylene/o2) would be alot quicker than Mapp let alone propane.
Mapp gas: ~5301° F (2927° C)
Propane: ~3614° F (1990° C)
Old 08-30-2008, 06:29 PM   #17
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Buy a press or take it to a shop that has one...
I only used a torch when I was burning out the subframe bushings...
Nikeboy355 is offline   Reply With Quote
Old 08-30-2008, 08:28 PM   #18
njd07
njd07's Avatar
njd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfection
Send a message via MSN to njd07
I used propane torch...juts gotta keep at it...takes a bit longer then acetaline torch...but owell all I had. just keep at it...try and get it to the point where its on fire burning by itself.
s13 parts fs:#/f/showthread.php?t=193416
sr parts fs: #/f/showthread.php?t=193399
s14 parts fs:#/f/showthread.php?t=193420
180sx part out #/f/showthread.php?t=203711
njd07 is offline   Reply With Quote
Old 10-07-2015, 10:23 AM   #19
drew_DST
drew_DST is an unknown quantity at this point
Wow I'm super late to the party! But I agree with those of you supporting the burning out option.
It's not neccessary or efficient to burn the rubber. All you have to do is heat the housing to break the chemical bond between the rubber and shell.
I have some detailed pictures of the process in an article I wrote about how to properly burn out suspension bushings:
http://www.aftermarketsuspensionpart...the-right-way/
There is also a video for anyone who doesn't like to read.
Now that it has been a few (7) years, has anyone had any negative results in this method?
drew_DST is offline   Reply With Quote
