![]() Join Date: Feb 2002
Enjuku Racing - PLX Kiwi 3 OBDII Scan Tool
PLZ Kiwi 3 OBDII Scan Tool ![]() ![]() ![]() ![]() Kiwi 3 is a plug and play automotive tool that connects to the onboard diagnostic port (OBDII / CAN), retrieves information from your car's computer, and wirelessly transmits to your smart phone, tablet, smart watch, or PC. Compatible with 1996 and later vehicles Kiwi 3 monitors MPG, data log engine parameters, read/reset engine trouble codes, monitor real time engine performance, fuel efficiency, driving behavior and much more. Easy as 1-2 Kiwi 3 is the next generation of OBDII adapters and no longer requires cumbersome bluetooth pairing or wifi configurations. Simply, plug and launch the app. Kiwi 3 does the rest! Engine Diagnosis and Monitoring Depending on the app and the vehicle's make and model Kiwi 3 can display: Air flow (MAF) Air intake temperature Ambient air temperature Barometric pressure Catalytic converter temp Coolant temperature ECU voltage Engine load Engine timing Evaporative purge Fuel level Fuel pressure Intake pressure (MAP) Long term fuel trims OBD type Oxygen sensor voltages RPM Short term fuel trims Throttle position Vehicle speed Distance traveled since code cleared Distance traveled with malfunction indicator And more ... The smallest, fastest, and most versatile OBD adapter yet Kiwi 3 is up to 4 times faster than the nearest competitor and uses ultra low power allowing you to leave your device installed permanently in your vehicle. Compatible with all standard OBDII protocols, Kiwi 3 installs in seconds. Firmware can be updated via Bluetooth and employs a nearly invisible design. When inserted into your OBDII port, Kiwi 3 sits just 0.68 inches thin making it the smallest and most discrete OBDII adapter. Cross Platform Compatible Kiwi 3 is the world's first true cross platform support compatible with iOS, Android, Windows, Mac, and Linux. Kiwi 3 allows for app developers to freely deploy without restrictions like the Apple Made for iPod (MFI) program. As a result, Kiwi3 is a simple and straight forward making it highly developer friendly. Apps for All To ensure a superior user experience we partnered with the world's most popular OBD app developers. Kiwi 3 is compatible with your favorite apps like DashCommand, Torque, Harry's Laptimer, and more! Vehicle compatibility *All cars and light trucks built and sold in the United States after January 1, 1996 were required to be OBD II equipped. In Stock and Ready to Ship! $99.99
