![]() Join Date: Dec 2009
extremly high fuel pressure
I have been trying to figure out what is up with my sr20 swap, the fuel pressure is around 80 psi at idel and i put a nismo adjustable fuel presure regulator on and when i adjusted it nothing changed, it just stays at 80psi. The car runs fine until u get into full boost and up around 4000-4500 rpms. Can anyone help me?
![]() Join Date: Dec 2004
Trader Rating: (58)
Does your gauge work? or is the FPR known working?
Remember Pump Feed Filter Gauge Rail In Rail Out FPR Return you should immediatly see a change when using an FPR and adjusting it.
#6 | |
Trader Rating: (58)
Do you have an FPR on it?
