![]() Join Date: Jul 2005
Trader Rating: (354)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 354 reviews
NO TRADES!
Will ship the seat at buyers expense! Looking to sell my Bride Zeta III w/ Gradation Type-L. Here are some specs on this seat. "The all new ZETA III Type L is the taller driver's model of ZETA III. The seat is taller and has wider bolsters, tailored for the taller driver. In all black, FRP construction. Type L is for taller drivers, for smaller drivers, see ZETA III Type S. Shoulder and side bolsters of ZETA III are purely for seat performance and feature the largest shoulder and side bolster for high driver holding ability. The frame is very durable and lightweight, and the fabric is all black Bride fabric with buckskin shoulder bolster pads, and a sparkling silver metallic finish on the backing." Info on seat condition: -No rips -Has a little wear, and I say that because its been used -Scuffs where you mount the seat(not visible when mounted) -Awesome seat that fits up to a size 34 Waist. Price:$600 Firm. **Prices include shipping and 3% paypal fee. Everything has shipping added but Megan DP** Price Drop! Splitfire DIS-004 Direct Ignition Upgraded Coil Packs S13 S14 SR20DET -I received these along with other parts and were said to be in working order(except for one possibly). ONE has burned at the top and I was told that it fell onto the exhaust manifold causing it to burn). I don't know for sure so I'm putting that out there. -Everything is included -The harness that's closest to the bottom(not the coilpack harness) has a connector missing.Needs to be hardwired. Second Pic. -Besides all that above, its complete. Price:SOLD[IMG]Splitfire DIS-004 Direct Ignition Upgraded Coil Packs S13 S14 SR20DET[/IMG] Battle Version Tension Rods -Good working order -Used Price:$135 shipped or $120 local Sr T25/T28,etc Turbo inlet/intake -Originally was a S14 T28 inlet but was extended to be like an intake. -Use on any turbo similar to a T25/T28, as long as it has 2 studs on the inlet(Nissan style turbo's) Price:$53 shipped or $40 local. How it sits mounted up. Test Pipe -Unknown brand -Never been used or bolted on before -Will come with hardware if I can find it Price:$45 shipped Megan 3" DP w/ Flex Section -Worked fine but LEAKS due to busted flex section -Cut and weld a piece for an easy fix. Price:$30 LOCAL ONLY Goodridge SS rear lines -I purchased as Z32 rear conversion lines but thats not the case. You can buy an adapter(cheap) at a fitting store to make them work. Will come with whats shown. Price:$35 shipped Last edited by Driven08; 01-17-2012 at 04:08 PM.. |
#5 | ||
I'll PM you |
