#1 | |
Coupe Rd. 2: FIGHT!
Be forewarned; I had to screenshot most of my content from my instagram. I didn't have time to be a fuckboi and edit fancy pics and write fucking articles about the art of building cars. Go read that chichi bhoy shit on stance nerds, speed humpers, or wherever else you get your fix.
Quick recap; had this for a few years, tracked it twice. Once with a shitty s13 sr, and another with my current s15 sr in it. Didn't bother updating that thread because fuck that nasty car. #/f/showthread.php?t...e+build&page=3 That shell was a throw-away, so I had my eyes open for a suitable replacement. Anything was fine as long as it had less rust than that, non-sunroof, full interior. This showed up on a page for local s-chassis owners, put a deposit on it as soon as I saw it even though it had a rumpled passenger door and lower pass rocker area. Put a deposit on it, took home the title along with these; The car had/came with: Good KA-DE, s14 5lug (obvi), Full set of 16x8 Starion wheels Q45 front brakes S15 HLSD Gen-3 Fortune Auto 500 Coils (one leaked) Sil-front with that sweet hood (no idea what it is) Boxes of spare parts (including Nismo 720cc injectors) I transferred what I could to my old car, sold the rest. Went and bought these jams. +30mm Origin Tatakadashi rears. Fitted up the new suspension. Ended up getting new BC Racing coils since Fortune Auto wouldn't service the Gen-3's that came on the car(two generations old). Also mocked up the corners and headlights. Engine bay got painted slate gray, then I fitted up the HMIC for my SR. BRICK SQUAADDD Got a burst of motivation and had it like this by nightfall. Drove it around all winter looking ugly as shit. So much bondo on the "repair" that the previous owner spent $500 on. I put a non-rumpled door on it, and there was so much bondo that the door couldn't close. At least one side is pretty-ish. Trendy pics for the nerds and dicklickers. Got my Origin +20mm fronts painted by my best friend. Rocked it like this for a few weeks. Had my wheels re-done by Neutron Coatings as soon as it got warm outside. Neon Yellow for that retinal burn! (another angle of the botched body job.) Pre-Touge string alignment Circa 1999, Goshen Prefecture, JPN. I finally went insane and chopped the rear quarters for the Origin overs. Can't get to -.5* of camber with stock metal and 17x9 et 17 wheels. Grippier alignment & better tire consumption > OEM metal. Found a 1/2" of bondo in some spots. That job sucked, but we prevailed. Repairing that nasty side was the worst of it. Decided that this is the season I will buy new tires to drift on. Wanted to give the Achilles ATR's a shot, ordered a bunch. One pair of fronts and one pair of rears pictured, still have 3 more pairs of rears. The remainder of the tires came in throughout the week. FREAKSHOW Getting this heap ready for paint. I had a two day drift event 4 days after this pic was taken. A week of late nights netted this, a fully kitted and painted car for the event. Media loved the car, and so do I. All we had to do on the race weekend was change wheels, a quick re-bleed of the brakes, and adjusting tire pressures. My friends and I did a great job with this one. Pics from Day 1 with RSD @ Poconos Fan Fair Shakedown (skidpad)
#2 | |
Pics from Day 2, Import Expo Drift Demo @ Poconos North Course (4th gear 90 mph+ entries).
Spectator clip of the tandem between me and Mike Perez here: http://wsvaco.tumblr.com/post/118814...reat/embed#_=_ Here is the current list of shit on the car as it sits in my driveway. Driveline: S15 Silvia Spec-R SR20DET Exedy Stg 2 Clutch Lightened OEM Flywheel Tomei Turbine Outlet LS2 Coil Pack Conversion ISPF Oil Pan Hoitsma's Harnesses PRO Conversion Harness Nismo Engine and Transmission Mounts Gt2560rs @ 10 lbs Turbosmart Boost Controller Spec R Ecu Function Motorsports High Mount Intercooler Function Motorsports Coolant Burp Tank Gk-Tech Eccentric Throttle Pulley Fuel: Walbro 255 Lph Pump 93 for DD use MS 97 for track use OEM 440cc injectors Suspension: Function Motorsports Front Lower Control Arms ISPF Tension Rods Parts Shop MAX Inner Tie Rods Circuit Sports Outer Tie Rods BC Racing Type BR Coilovers Swift Springs 8k front, 6k rear MoonFace Roll Center Corrected Front Ball Joints (ordered) J30 Rear Sway Bar Energy Suspension Bushings SPL Solid Subframe Risers ISPF Rear Control Arm Kit Brakes: Braided Stainless Brake Lines Q45 Front Calipers Stop Tech Slotted Rotors Porterfield R4-S Pads Rebuilt OEM Rear Calipers Circuit Sports Rotors Hawk HP + Pads Gk-Tech Extended E-brake Actuators Exterior: Silvia Front End Origin Labs Hood (?) Origin Labs 20mm Front Fenders Origin Labs 30mm Tatakadashi Rear Fenders KQ's Front Bumper with Piggy Lip BRICKS G-Grow Side Skirts JDM Rear Valances Interior: Innovate LC2 Wideband Controller and Gauge x2 Parts Shop Max EVDM 350mm Key!s Racing Semicone Steering Wheel Sparco Steering Hub D-Max Quick Release Tomei Duracon Shift Knob Nagisa Auto Seat rails Genuine Sparco Evo II US GK-Tech Ebrake Button Isspro Boost Gauge S14 Seatbelt Retrofit RaceQuip 5lb Extinguisher Wheel & Tire Front: ATR Sport 2 (225/45/17) DR-31 17x9 +17 Rear: ATR Sport (225/45/17) DR-31 17x9 +17
Nice build man keep it up! I see your using the GK tech ebrake extended actuators, do you get good lockup performance out of those? just wondering im building a hatch right now and ive installed those but haven't drove the car yet.
we spoke about that once before, you didn't get back to me about it lol
#8 | ||
Also, the GM coil packs have internal ignitors just like the s15 sr ones. We can't get replacement s15 sr coil packs here in the US.
#9 | ||
As far as lock up "performance", it REALLY depends on the kind of pads you run. I run Hawk HP+ pads in the rear of my s13 when I'm at the track, and the pads aren't so great when they're stone cold. But after a few yanks, they come to life and lock the rears with little effort.
#14 | |
Clear is starting to peel, but thats easy enough to fix.
#15 | |
Thanks! It's an Isis Performance MBSE cat-back.
#16 | |
#17 | |
It was already green when I bought it, but it was Tk3 out of the factory! You can still see it in the car at the trans tunnel and stuff.
#18 | |
#20 | |
Went off track towards the end of the day, smacked the back side of the track curb..
Blew a chunk off the face of my wheel (still held air all the way to the pits) Chunk of said wheel bounced off the ground and ripped my stainless brake line Bent PBM tie rod 45* and the ISR Tension rod 60 degrees. Pics to come in a few!
#22 | |
I'm entertaining offers on the car... I want to keep it, but after I finish my next car, I won't really use it much. I'm probably going to regret this.
