Old 12-13-2009, 08:59 PM   #1
Rbrum
Rbrum is an unknown quantity at this point
confused on clocking this!?
the angle of the turbo is so annoying. because of the actuator bracket it dosent seem like it will angle up anymore so i can run a better hot pipe. the one i have now runs down up back down and take up so much room that i have to run the intake across the front of the engine. any advice would really help im just out of ideas
Rbrum is offline   Reply With Quote
Old 12-13-2009, 09:34 PM   #2
Sileighty_85
Sileighty_85's Avatar
Remove the turbo and look on the back and you will see bolts with holding brackets.
remove the brackets and you can clock the turbo, the actuator bracket also serves as a holding bracket for the compressor housing so just move it accordingly.
My set up
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-14-2009, 05:16 AM   #3
Rbrum
ok so just take off the actuator and bracket then clock the turbo like you have it then remount the bracket?
Old 12-14-2009, 05:30 AM   #4
Sileighty_85
Right also you might have to remove the W/G Actuator from the bracket and flip the bracket around
後輪駆動車1番
1986 SR86 - 200ish
