![]() Join Date: Dec 2013
s13 speedometer not working
ok its a 1990 hatch that had a sohc previous owner swapped s14 sr20 European model. When i got the car the wiring was a mess noting worked so i rewired the whole engine harness now i got most of the stuff working. Tach dont work because its a sohc cluster the speedo is all wired right has power ive rechecked everything. Will this get fixed with a dohc cluster or do i need to run s13 speedo?
![]() Join Date: Feb 2012
Trader Rating: (37)
I understand the concern that you have, but this has been talked about countless of times. Google will tell you what you need to know, and you'll get a much quicker response.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
