![]() Join Date: Apr 2010
https://www.youtube.com/watch?v=tZhG...e_gdata_player
Non turbo all stock motor. Air filter is clean. |
![]() Join Date: Sep 2005
Check your ecu for codes!
Unless it's normal for the check engine light to be on while the engine is running!!!!!
Check the codes and go from there, but off the top of my head, like stated before
-tps -iacv and I would check the MAF if its plugged in all the way. Pull it out and check to see if the male pins are straight and not bent. Check vacuum lines also, just my $0.02, good luck
1995 240sx SE 5spd Red/Black 1993 240sx 5spd Coupe Red (SOLD) |
ok update on what i did
i pulled my intake and t/b off and cleaned it all plus pulled egr valve and pipe off and cleaned too. and then used seafoam on oil, gas, and intake system to help clean all the carbon out. then this happened... http://youtu.be/N1o35WPj3RU found the problem to be the egr gasket was leaking air so i replaced it and now motor seems to b running fine. but my idle is staying bout 1100rpms.... but after i did all that i went to smog the car and it failed 2times and the second time was worse fail than the 1st plus my check engine light came on during the 2nd smog and im throwing up error codes (12 and 32).... can some1 help or give advice on what i could do? im running all stock 91 ka24de motor with 5speed tranny.. |
so have you tried swapping your mafs with a known good one and addressing the egr function problem?
not rocket science, but you do have to fix the codes before it'll work right ![]() |
Ya I need to do the timing chain too
But I bought an o2 sensor and ngk spark plugs. Idk if I wanna smog it just yet cuz I was thinking of doing that consumer assistance program to pay up to $500-$1000 to smog a car |
#17 |
did you ever figure it out?
I have the same problem swapped my motor from my 96 to 93 idk if i did something wrong when i switched the intakes but car will not idle i have taken it to many places cuz i got tired of screwing with it but no answers?
