#31 |
![]() Join Date: May 2009
Trader Rating: (31)
![]() Feedback Score: 31 reviews
Thats pretty good as i get 17-18mpg currently. I wish i could get 24mpg.
VISIT OUR NEW SITE! streetfaction.net |
#33 |
#34 | |
![]() Join Date: Jan 2011
Trader Rating: (26)
My SR is technically a SR22 but I still get 30mpg lol. PS-Forged internals really really really kill gas mileage. In the mornings when I warm up I'll probably get 24mpg cuz of the warmup. I have to admit these are some clean KA-T setups. I usually see them done shitty, quick and half assed
IG/TikTok-ThatS14_Z06guy
#35 |
![]() Join Date: Feb 2007
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
The tank is ~15 gallons but not quite 16 gallons so thats between 26-27mpg.
But my calulations of 420 miles per tank full are based on using 14.5 - 14.9 gallons of gas because I didn't want to run out of gas obviously so based on that almost 29mpg's so its not to bad bad. My bone stock S13 KA24DE sucked in the MPG department but that was mostly do to the knock sensor shielded singal wire which very commonly fails on teh S13's and shorst to ground via the shielded cable making contact with the singal line inside this multilayer wire, but thats a whole other story. I guarntee you hardly anyother KA24DE-T will even come close to my milage and I bet they will agree. |
#36 |
Trader Rating: (40)
Thats a major fail oil return setup (for no AC), the oil return is gravity drained, you taped into the easy way which is the wrong way. Oil can back up in your return line and overfill in the CHRA and raise to the level of the oil control ring and start leaking fuel into the turbine side of teh housing which will start cokeing up and turn into hard carbon deposits and wear yoru turbo out prematurely.
Mines work for both AC and no AC because I thought it threw and yes my KA-T had full AC. |
#37 |
Could be.. But haven't had any issues like that on any of the KA-T I've done and helped. General rule for oil return is to keep free flowing and as high in the pan you can place it.
BTW that Modded PAN came from a Formula drift car. Dont think he had that issues. ![]() |
#38 |
Trader Rating: (40)
Well I know that 4 full quarts of oil will fill up to the almost very top of the pan where it meets the block, granted there is never gonna be a full 4 quarts setting in the pan while driving but its still better to be safe than sorry, I know this because again I filled up the oil pan with 4 quarts of water when the pan was off to see where the maxima height of oil would reach and this is how I came up with my oil return location.
Beyound all that, if that doesnt even become a problem its still not a good location to tap for the return as the oil exiting the CHRA is frothy and air being sucked up by the oil pick up is not a good thing. This is also why turbo oil drain lines are large. |
#40 |
Trader Rating: (40)
These aren't things your not gonna see be an issue right away, again im about reliability and the long haul im not satified with 2 or 3 years usage before im replacing the turbo or an engine. Just here on zilvia alone you'll read more threads mentioning a T25 failed in one week, like if its widely accepted that its cool if you get a year or two out of them lol....but thats also due to running improperly adjusted BOV also (compressor surge).
#43 | |
Trader Rating: (40)
Stock Internal KA24DE SSAC BMM 370cc stock FPR (no need for an adjustable one just yet) stock S13 SMIC w/all piping stock KA24DE ECU with Nistune Type 3 Board Z32 TT fuel pump with re-wired relay for 14v all teh fuel pump GM 3 bar MAP sensor for logging boost/vacuum Apexi AVCR Apexi Turbo Timer Apexi GT Spec Exhaust Innovate LM-2 wideband Defi Link meter sytem with fuel and boost gauge's CUSCO Subframe bushings CUSCO Engine mounts CUSCO F/R Strut tower braces Kei Office coilovers Full ES suspension bushings SPL RUCA's SPL Adapter brakcets for 12.76" 350z brembo pkg rotors with Z32 30mm calipers Full working S13 digital climate control S14 98 model year seats G35c 18x8 +30 wheels Electric fan conversion 5 lug conversion rear hubs from Z32 5 lug conversion front with J30 hubs and S13 spindles with custom sleeves and spacers I made for it probably left some stuff out |
#44 | |
![]() Join Date: Apr 2009
its not hard to get good mileage with a good tune and proper driving |
#47 |
#48 | |
Trader Rating: (40)
This is before the front was painted and bigger brakes put on and the car being droped a little more, my car looks like a stock car probably why I never got harassed even though I had a huge ass Apexi GT Spec exhaust which is very quiet by the way. The hood is also carbon fiber. |
#49 |
![]() Join Date: Feb 2009
my sleeper status
![]() LOL jk... But seeing these really makes me want to build another for daily with this sleeper status that way i can love my 40s and never loose boost
![]() JUST A RED TOP SR |
#51 |
damn i want a ka... but my lambo came with a sr so its staying cause im lazy lol... new lids i like that turbo
#52 | |||
![]() Join Date: Dec 2004
Trader Rating: (58)
Either way nice setup. Nice and clean, just like my car ![]() Quote:
Turbo size isn't indicative of good/poor fuel economy, condition of engine and tune are. If anything the car should see better fuel mileage with a smaller turbo due to increased torque and lack of fuel/throttle needed to accelerate.
#53 | |
I was actually just thinking that and the fact that most of the times you go to a lower comp piston... it all comes down to the tunes.. your not boosting your car to make good gas milage are you? if so just go by a insight or a prius
#55 | |
![]() Join Date: Mar 2009
Trade my Rb25 for some wheels. Buy my Sc300. |
#56 |
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
I get 17-21mpg on a stock ka24e. I don't think that's too bad. What are you secrets to getting 25-27? I plan on joining this thread sometime but I'm wondering how you pull the extra miles out your asses lol
#57 |
![]() Join Date: May 2007
well a dohc is much better on gas trust me. also check all your sensors they help alot.
to be faster you have to slow downWTB OEM SILVIA AERO SKIRTS!!!!!! PM ME |
#58 | |
Either way, I'm glad it hasn't happened yet! Sleeper from this angle Lmao Awesome thread, I love how these are looking! Pretty much made up my mind about future plans for the Vert.. these pics are quite motivating haha ![]()
Friends don't let friends build SR20's. Have faith in your KA!! |
#60 |
I'm a tad confused with this thread... Perhaps "hidden" ka-t setups would be a more appropriate theme; I don't mean to burst anyone's bubble but a dinky t25 sidemount intercooler ka-t setup isn't "sleeper". It might look similar to original equipment but it's still pretty measly performance wise.
