![]() Join Date: Mar 2010
stupid rusted bolts...
i had the same problem on my s13. i ended up replacing the entire knuckle because i couldnt get the bolt out...
the lower bolt on the front strut of my s14 is froze. ive been beating the heck out of it, pb blasting it daily, and it just wont budge... im sure there has to be a trick out there someone uses to get these loose? |
Try heating the nut with a torch... You can heat it and let it cool or heat it and quench it. You may also want to use a breaker bar on it for additional trq.
My SR20VET |
![]() Join Date: Dec 2004
Trader Rating: (58)
Have you tried impacting it? YOu'vbe put a long pipe on a breaker bar too?
Trader Rating: (58)
Yup. It happens on my Macphearson style setups that have never been off
#17 |
i dont have an air hammer. i tried turning it with a breaker bar andjack handle but it started to strip the bolt so i stopped. i tried using a rusted bolt socket and it snapped the socket. i have been beating on the end of it with the nut threaded on with a 10lb sledge hammer. no luck. thats when i made this thread.
going out to heat the bolt and quench it. hopefully that works. |
#19 |
Living in the midwest I've been through this several times. Heat the knuckle with a torch like said above, and then with an impact on the bolt head try to spin both ways. Heat, spin, heat spin opposite way, repeat. That was how we got our best results.
Also have used a c-clamp before and with heat, pushed it out. |
#20 |
Man w/ CTSV & a Car Seat
Shit, I swapped exhaust out and the bolts are pretty much rustwelded in place. PB blasted it and torched it to no avail. Eventually, the nut just rounded off after using a breaker. Took the fucking grinder to it and just cut it off...
#21 | |
#22 |
Well what sucked was I got the first one off permanently...the dam stud just broke off. When that happened, I knew already the 2nd one is gonna be a bitch. Murphy is my hommie...when shit goes wrong, it just gets worst.
#25 | |
#27 |
you obviously know nothing about mettallurgy. the knuckle would have to be heated glowing hot for several hours and then cooled in a matter of seconds for it to become brittle.
#29 | |
btw why is grey cast used on parts that take heat (engine block) and white/malleable cast used on areas that dont get heat? have fun with your rust bucket |
