![]() Join Date: Apr 2004
1996 240SX S14 USDM F3 pinout
Reposted from Russ's post with some of my updates to fill in some of the gaps.
orange, headlamp diode (not sure on this one) 1-black/red, switched power from Fusible Link and Fuse Block-2, 30A fused, thick wire lead to injectors, coil, ECU 2-black, ground for CONSULT (not sure on this one) 3-blue/red, rear defogger/electrical load signal (I don't see this in the FSM) 4-pink, washer switch 5-light green, ignition lead to wiper motor 6-light green/black, wiper motor high 7-light green/red, wiper motor low 8-brown, wiper off/int switch 9- 10-black/yellow, fuel pump signal to F23, Idle Air Control Valve (IACV)-Air Regulator, EC-309 in the FSM 11-black/pink, fuel pump relay ground signal 12-black/yellow, fuel pump signal 13- 14-green, CONSULT 15-purple/white, P/S oil pressure switch, but also green/white, CONSULT according to the FSM 16-yellow/black, AC & defroster switch 17-red, constant power from Fusible Link and Fuse Block-2, 7.5A fused, to main ECCS power, Camshaft Position Sensor, Mass Airflow Sensor, and Purge Control Solenoid Valve 18-brown, switched power from Fuse Block, 10A fused, to O2 sensors, EGRC solenoid, EVAP purge/vent solenoids, Idle Air Control Valve (IACV)-Auxiliary Air Control (AAC) valve, TPS 19-black, not sure on this one 20-red, GST port 21-yellow, GST port 22-green, CONSULT port (not sure) 23-green/white, CONSULT port (not sure) 24-yellow/green, VSS signal 25-orange/blue, cooling fan high signal 26-yellow/red, tachometer 27-blue/yellow, wiper intermittent switch 28-yellow, temp gauge sending wire 29-Blue/White, ambient air temperature switch 30-orange, MIL lamp 31-blue/white, ASCD actuator power 32-blue, ASCD air valve 33-yellow/blue, 5th gear position switch 34-orange, start signal 35- 36- 37-orange/blue, recirculation relay 38-green/black, CONSULT port 39- 40-green/orange, neutral position switch 41-blue/green, cooling fan low signal 42-purple, wiper variable intermittent switch (SE only) 43-black/pink, triple pressure switch signal 44-blue/red, IACV-FICD signal 45-orange/black, triple pressure switch line 46-ornage/blue, AC thermo control amp 47-green/yellow, ASCD release valve 48-blue/black, ASCD vacuum motor Last edited by g6civcx; 12-21-2009 at 08:28 AM.. |
![]() Join Date: Sep 2007
Is this taken directly from the FSM? When i was wiring my motor in I noticed there were many differences between the FSM to the actual car. The only way I made any sense of it all was tracing each individual wire to the ECU.
#3 | |
I did the best I can with the FSM, but the best way is to trace each wire to the source. |
