![]() Join Date: Feb 2011
Steering wobble
so heres there problem when i go 60 mph or over my car steering wheel shakes and so does the car.i have had my wheels balanced, my suspension checked and my frame looked at to make sure it isnt warped. people tell me its a rim but wouldnt a rim do it at any speed? any info will be greatly appreciated.
I had the same problem on my S14 (steering wheel shaking over 60mph) so I changed my inner and outer tie rods and steering rack bushings. Then I got a alignment and now it drives perfectly fine.
I'm having the same issues. Had alignment. Changed inner and outer tie rods. But I believe it might be the tires are cambered from previous owner driving on blown struts with lowering springs. We shall find out soon!
Yea man will do .
Changing out all struts then test driving had a clearance issue with kyb agx struts rubbing the tires. Once I get that fixed with some spacers, Ill see if it takes care of the wobble. What are you running for suspension? |
![]() Join Date: Sep 2009
![]() Feedback Score: 15 reviews
I kinda have the same problem, but once I brake the wheel wobbles. It started happening after my alignment. Car drives straight but only wobbles under braking like I said.
straights are for fast cars, corners are for fast drivers. |
#9 | ||
Ok thanks. Im on megan coils
![]() Join Date: Jan 2011
My buddy was having the same problem, and it turned out to be his rotors. People argued that rotors would only cause a shake while braking. But once we changed out his front rotors, the shaking stopped at high speeds and on braking.
![]() Join Date: Dec 2006
I have a similar issue on my S14 but have reason to believe its my Rack and Pinion bushings.
Since I have Stance Outer TRE and Tein Inners Just got in my OEM R&P bushing set so well see if that fixes my issue
#20 |
i have the same problem in my s14(braking wheel wobble) i'm replacing tie rods soon. did you ever solve your problems, if not tie rods what else should i replace while i'm down there?
#21 |
![]() Join Date: Mar 2011
Had the same problem with my 14, the tread on my front tires were seperating due to old age, so many things it could be. 60 mph wobble is normally wheel balance.
#22 |
i have always noticed the slight wheel wobble around 60 and never been concerned. However, when i break lightly from around 60 i get a lot of wheel wobble but when braking hard or with downshift wobble goes away(strange). I have always assumed that if could be a few things which could include: tie rods, brake rotors, balancing, uneven tire wear(lowered car, uneven tire wear in rear and when rotated to front tires wouldn't sit flat as they if they didn't have uneven wear). Anyway, I am replacing my tie rods because they the outers are worn out, and im going to have the rotors spun while i have everything taken apart.Ii'll update with whatever results i find.
#23 | |
