![]() Join Date: Jan 2011
Trader Rating: (43)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 43 reviews
I'll be updating with pictures as soon as I get them.
Taking a different approach on plans for my s14 so I need to sell my engine. Shipping is available but you have to pay. Call or text 562-207-81two/nine - Louis for fastest response. HKS GT-RS turbo approx 3000 miles - SOLD HKS SR20DET turbo exhaust manifold $450 HKS turbo elbow dimpled to clear steering column $150 Nissan JDM S14/S15 SR20 Water Outlet $50 Nismo 740cc Fuel Injectors (4) in rail $500 Tomei Procam 260 degree intake camshaft $150 Tomei Procam 260 degree exhaust camshaft $150 Greddy Intake Manifold with ISIS N15 Throttle Body Adapter Kit : SR20DET and Nissan 16119-1N510 70mm Throttle Body : N15 $900 Greddy 70mm (3 inch) cold pipe to match n15 throttle body $60 Greddy Valve Springs SR20DET $100 Brian crower titanium retainers $200 Or head with valve springs and retainers, rocker arms, shims, brand new freeze plugs just decked; Basically a complete head ( with exception of cams but I'll throw in stock cams and used apexi head gasket) ready to go for $450. Tomei oil pan with small ding (not a dent). $250 Sard adjustable fuel pressure regulator with gauge $100- SOLD Greddy SR20DE T rocker arm stoppers $50 S13 stock red top swap. Comes with new blacktop valve cover, new oem oil pan, new starter, new alternator, new oem s14 water pump, HKS rocker arm stoppers, conversion heater hoses, just resealed oil pump and upper and lower pans, s13 sr into s14 harness (needs cleanup), #62 Ecu and 5 speed transmission. Needs turbo, turbo manifold, clutch and pressure plate to be drive able. $1600 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by AutechKouki; 07-18-2013 at 05:21 PM.. |
| greddy, hks, s13, s15, tomei |
