Sway bar size
Hey for all you S14 serious road racers out there, what sway bar setup are you running? How big do you guys go as far as size?
Thanks! Edit: If this should be in the road racing section, sorry!! >< |
Im running a tanabe 30.4 mm front sway bar so far an the car just grips. But I also did the hyper flex master bushing kit an rear subframe solid gushing an the car will hold 50-55 on a turn rated for 20-25. Just sayin that my setup. An I have a s13. I know ur lookin for a s14 setup but it's some ideas. Enjoy
