Speedo acting real funky
I have an 89 hatch with a ca18det in it. the other day i was replacing my injector o-rings so i pulled the harness to the CAS, Temp sensors, Injectors, 2 grounds on intake and the iacv plugs. after i hooked everything back up i went to turn the car on and when i turn the key to power the speedo will jump up to 15 mph and sit there even after the car is on. sometimes it will jump around as far as 40ish mph. anyone ever seen something like this? i tried looking online but if you put speedo in the search theres a million write up for analog to HUD, mine is and will always be analog. the speedo has been acting up for awhile and not working unless its warm outside.
