#35 |
SR20DET Valve Cover - 95.00 Shipped.
For Sale: - Active Threads - OEM SR20DET Parts and Accessories - SR20DET ARC Aluminum Induction Box - S15 Spec R Alcantara Seats - Tein Super Street S13 Coil-Overs |
#36 |
R32 Skyline 30MM (296MM Rotor Diameter) -
245.00Shipped Z32 Aluminum 30MM 225.00 Shipped Set #1 Z32 Aluminum 30MM 225.00 Shipped Set #2 Z32 30MM Iron Calipers 215.00 Shipped Set#1 Description: All Sets are Fully Loaded with used pads, shims, pins and fasteners. All rubber boots are intact. If you have any further questions or concerns, feel free to PM for further details and inquiries. Thank you J.
#37 |
S14 / R33 Skyline OEM Rear Lower Control Arms AND Ball-joints - 120.00 Shipped
Description: This set of OEM S14/R33 Lower Control Arms are in excellent condition. The bushings are healthy and the Ball-joints are intact.
#38 |
Greddy Profec E-01 - Brand New
415.00 Shipped
#39 |
S13 Silvia Corner Lights
120.00 Shipped Description: These Amber S13 Silvia Corner lights are in excellent condition. All tabs are intact, and the lenses are in very good to excellent condition. Normal wear and tear is expected. These lights are as described, and as pictured.
#40 |
S13 Silvia Headlights
250.00 Description: These OEM S13 Headlights are in excellent condition. All tabs are intact, and the lenses are in very good to excellent condition. Normal wear and tear is expected. These lights are as described, and as pictured.
#41 |
SR20DET 370CC Injectors
135.00 Shipped and Paypalled. Description: These OEM SR20DET S13/4 370CC Fuel Injectors are functioning as they should, and have come from a clean-running SR20DET, imported directly from Japan, housed, here, in North America, and are in very good condition. This does come with the Fuel Rail and Fuel Pressure Regulator.
#42 |
SR20DET CAS - Cam-Angle Sensor -
100.00 Shipped
#43 |
OEM S14 5-Lug Conversion
300.00 Description: These are Genuine S14 Front Spindles with OEM 5-Lug Hubs along with Rear Z32/R32 OEM 5-Lug Hubs with Anchor Bolt Insert should you decide to opt for an EBrake assembly in the rear. N.B. If you are running S13 Front Lower Control Arms, please make sure to press in S14 Front Lower Control Arm Balljoints with these spindles.
#45 |
PM Sent - check your inbox.
#46 |
#47 |
Genuine OEM Silvia S13 Front Fenders
450.00 Shipped Description Below Description: The Fenders are in very good condition - one lip is slightly scraped in a little and needs to be massaged, but any competent body man will be able to fix that properly. All mounting points line up, and everywhere else is in excellent condition.
#48 |
Silvia S13 Front Fenders - Sold, thank you.
Set # 2 coming shortly.
#51 |
I did not even give you a price, are you speaking to yourself?
For everyone else - Silvia Fenders Set #2 pictures coming tomorrow.
#52 |
i didnt wanna look like "that guy"... so i re-read the power steering pump section and it was $120 for the pump then $55 for bracket, i just need the pump. So to restart the question do you have the power steering pump only, i dont need the pulley either if it helps?
