FS/FT: 2004 Nissan 350z shell
2004 Nissan 350z
Car comes with all stock body. Some are white, others are black. All in good shape. BC racing coils Tein inner and outter tie rods New steering rack All bad bushings replaced with polyurethane bushings eBay adjustable front camber arms SPL spherical tension arm bushings Welded diff Solid rear subframe bushings Solid diff bushings Adjustable rear control arms (camber and toe) Arp extended wheels studs Enkei Pf01 wheels (does not come with battles) Sparco Corsa seats and belts Stock 5 speed pedals Slotted rotors Stop Tech Brake Pads No windshield No title Stock fuel lines in tact (and stock tank) Stock brake lines in tact from passenger front wheel well to the back brakes Brand new headlights Used tail lights $6,000 obo Also have 1jz vvti motor, wiring, Collins adapter plate, clutch, flywheel, pressure plate, hardware, and vq trans and drive shaft that is ready to go into the 350z. Needs motor mounts, but the rest of it would bolt right up. This would come at an extra cost to you or could be worked in on a trade. Any questions feel free to ask Open to any and all offers Rest of pics can be seen here http://s42.photobucket.com/user/behe...y/?view=recent Last edited by getsideways; 10-28-2014 at 11:56 AM.. Reason: post pictures to page instead of link to the pictures |
| 1jz, 350z, bc racing, race, spl |
