![]() Join Date: Jul 2011
Some parts baller, some not
!!!!!UPDATE, NEW PARTS, GTI-R INJECTORS, G20 B&M SHORT SHIFTER, NISMO??? ADJUSTABLE TYPE A FPR!!!!!!
Check several posts down in the thread for pics and pricing. Thanks. Cleaning out my garage and finally decided I'm not gonna use this stuff. So once again I come bearing gifts with reasonable and cheap prices. Almost everything is O.B.O. .....almost. Any quetions for better pics or numbers off of parts, just ask, multiple items gets a discount. Thes discriptions are to the best of my knowledge, I parted out my gti-r powered g20 4 or so year ago so my memory is a little foggy. Some of the stuff is specific to the fwd sr and some is universal, but at your own knowledge of the parts, but like I said I will help serious buyers figure out what they are before they purchase it. I'm not here to screw anyone, so offer and ask away you part hungry wolves. Lets get it onnnnnn!!!!!!!!!!!! gti-r oil pressure sending unit $25 bluebird/gti-r ingnitor chips or whatever $20 each bluebird/gti-r external coil $25 stock boost pressure sending unit $20 sandwich plates, not sure what they'll fit $20 Flywheel $50 was a bluebird until i had the holes drilled out to fit the gti-r so now its for the gti-r, jgy 6 puck sprung hub clutch $50 and pressure plate $50 will fit the bluebird tho about 5,000 miles on clutch and pressure plate sr20 fwd starter $40 2.5 to 2.75 elbow intercooler, made from exhaust pipe ghetto style $10 oil pump, timing chain, guides and bolts from my s13 blacktop. They were in good working order but when I rebuilt it I got new stuff $50 Random sized couplers $25 for all of em bluebird/gti-r heat shield $20 2 inch samco couplers $100 unknown brand intercooler, was told HKS but no identifying marks $175 se-r ecu $100 and jim wolfe ecu z32 maf and 740cc injectors $400 random 2 row cooler $25 A-piller dual pod $20 gti-r top feed fuel rail $20 BOV mounting pipe $45 t25- t28 turbo connector??? 3 flange bolt pattern mounts it to the stock s20 turbos $10 after turbo 5 bolt pattern O2 housings on skinny adapter one fat adapter $25 each bluebird water pump $20 bluebird/gti-r water necks $10 each Stock BOV's big one gti-r, smaller one bluebird $50 each Stock MAFS, not exactly sure which motor they are for $50 each Apex AVC-R boost controller $300 comes with EVERYTHING apex turbo timer $50
seriously make an offer, this shit needs to go. I'm open to just about most offers. Give it a try and see what happens.
Seriously, I shoulda looked that up before I posted it. New price-$50 bucks on the turbo timer.
thanks edwin.
more stuff and more pics
axles I ran with my GTI-R in my 92-93 g20, pretty much new. $150 for both. TurboXS dual stage manual boost controller $200 obo The plug that comes with it had the wires ripped out but there are little pigtails in there that a mad scientist with a solder gun might be able to save. I'm throwin it in so the buyer knows what plu to buy. Nsimo? type A adjustable fpr. Maybe someone can clarify. Real $100 fake $50 GTI-R Jecs 444cc topfeed injectors. One has a split plastic pintle cap, but from what I'm told its a relatively simple fix. 0A50 0828N is the #'s on the top of all inj's. $200 obo B&M g20 p10 short shifter. Works great, ran it for about 10,000 miles. $125, even comes with original receipt. As always if you want more specific pictures, just clarify what exactly you want a picture of and i will get them for you. Enjoy.
