![]() Join Date: Sep 2003
Boosty - Street build LS# s13 coupe 5.7L
Power/current specs:
HP 384 TQ 370 Dyno Dynamics 450 DS Engine: - 5.7L LS1 - Fast 102mm intake - Fast 102mm big mouth throttle body - Holley EFI LS fuel rails - 243 z06 heads with sodium filled valves - 650" dual valve spring kit - LS7 lifters - Comp Cams trunnion upgrade kit - Comp Cams 7.3" 5/16 push rods - Comp Cams XFI XR277HR cam - Forged Mahle pistons - stock rods Engine Dress up: Holley LS valve covers Chasebays - relocation brake lines Plasti dipped intake MSD wires Suspension and handling: s15 5 lug conversion Stance GR+Pro LS swapped specific Sikky front swaybar 32mm tubular Tanabe rear swaybar 27.5mm Wheels and tires: Work VS-KF burning black front: 18x9.5 +7mm (107mm Lip) 225/45 (needed 4mm spacers to clear the z32 caliper) rear: 18x11 +20mm (120mm Lip) 265/35 (needed to bash rear inner tub, 8mm spacer to clear the inner wall) Braking System: front: s15 4 pistons rear: stock Exterior s13 silvia front conversion s13 silvia aero front bumper s13 Chargespeed silvia aero front lip s13 chuki 180sx side skirts s13 Bomex Bonneville rear valance s13 Dmax roof spoiler s13 Circuit Sports taillights Love these s15 seats ![]() Rusty frame rails repair. ![]() ![]() New metal! ![]() Por15 On some ugly ass MRR 19x8 and 19x9 ![]() Temporary fix... Varrstoens. 18x9.5 18x10.5 ![]() Onto a face lift. Good bye number5 and hello silvia ![]() ![]() ![]() Ugh.. don't like the fitment of these Origin fenders.. added Bomex Bonneville rear.... It's RARE! ![]() I got a free jdm aero bumper for free but it was cracked and warped but I got it fixed! Like brand new again! ![]() ![]() Back with the oem metal fenders ![]() Very last order of these VSKF from Ravspec ![]() So lucky to buy these brand new ![]() ![]() ![]() ![]() 18x11 +20(12)265/35 needed inner tub bashing and a 8mm spacer ![]() ![]() 18x9.5 +7 225/40 (needed a 4mm spacers to clear the z32 caliper) 18x11 +20(12) 265/35 ![]() Found a aero lip for sale.. not sure the brand.. Vanquish? Looks like the old school Chargespeed aero lip rep. ![]() ![]() It's getting hard to find oem parts. Found this from a zilvia member in Thailand. ![]() ![]() ![]() An impulse buy... should have gone with a crate engine instead... ![]() She's going under the knife. ![]() ![]() What a mess.. ![]() ![]() ![]() ![]() Can't decide on cutting the factory tubs out or not. [email protected] it go big.. more work. ![]() ![]() ![]() Last edited by boost infested; 04-25-2016 at 11:39 AM.. |
Don't judge too hard first time doing this lol. I don't have a plasma cutter everything was cut by a die grinder. This is also my first time doing this sort of work.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Ok, I am so sick of grinding. I cheated with seal sealer over welded area. ![]() ![]() ![]() ![]() ![]() BNR34 white QM1 ![]() ![]() ![]() ![]() Last edited by boost infested; 10-04-2014 at 01:23 AM.. |
Mahle forged pistons with Comp cams XFI XR277HR cam 54-418-11
![]() low mileage 243 heads from a LS6(z06) with sodium filled valves. Manley Valve dual spring kit with titanium collars .650" lift max. ![]() a quick test fit.. ![]() ![]() Sikky LS swap parts bought with Wiring Specialties. ![]() ![]() ![]() My stock intake came broken. So I replaced with the FAST 102 intake and throttle body. ChaseBays z32 brake master hide away brake lines. ![]() Tremec Magnum 6spd. The length from the bell housing to the shifter is 26.6" vs oem t56 is 29.5" The difference of 2.9". The oem t56 is already about 1.5" away from the center of the s13 shifter hole. To fix this you must use Sikky's 350z LS swap magnum shifter. Version 2 is ready to roll (June 22nd). You also have to get a Spicer slip yoke(1330 Series 31 spline) and YOU HAVE TO SHORTEN THE SIKKY DRIVE SHAFT. ![]() A quick test fit with just the bell housing bolted up to the long block. ![]() Monster Clutch Level 3 700 HP/TQ with light weight billet 18lbs flywheel. ![]() ![]() Last edited by boost infested; 10-04-2014 at 01:22 AM.. |
I added DEI fire sleeve to the brake lines. Body harness is 95% re-wrapped. Not sure where I am going to put the oil filter remote mount yet.
Waiting on - Sikky Magnum shifter - Sikky RH header - shortening the driveshaft. - battery relocation to the trunk - brackets for the radiator fans ![]() ![]() Last edited by boost infested; 08-31-2014 at 01:31 AM.. |
![]() Join Date: Apr 2003
Trader Rating: (33)
Literally sitting here in my office drinking tea just envisioning this project once completed. I wish I had half the fabrication skills and 1/5 the attention to detail.
#25 |
First world problem,I can't close my hood. After removing the underside bracing, the damn 4" elbow still in the way of the hood. Fast104 intake manifold, throttle body and a 4" elbow is just slightly too tall for the hood to close.
Second option, carbon creation hood. I personally don't like it but I made it some what closed for now. ![]() ![]() ![]() ![]() ![]() ![]() ![]() 5 hours later lol I still like the factory hood style better.![]() |
#27 |
![]() Join Date: Sep 2009
Time for a Origin Type 2 hood. Its only hitting in the front at the elbow? I would almost bet it will hit on the intake, right where it says LSX, once you got the eblow/tb to clear. Thats where my 102 just kisses the hood.
#29 | |
The stock hood with the bracing removed the "LSXR" part will still touch the underside of the stock hood. My carbon creation one will clear the "LSXR" part but the 4" elbow still touch the flat part of the under hood. |
