FYI: 92 240sx fastback/ stock KA24DE
since i got the car the a/c hasn't worked. so today i figured i would try to recharge it. i went and got a retro fit kit. as soon as i hooked up the gauge, it was in the red warning area. so i let out the pressure and recharged it. it would only recharge a little at the time. so i put two cans in it and still no cold are. the a/c button light is on, the car idles up when i cut the a/c on, but still no cold are. prolly something else that is more expensive. could someone please shed some light on this subject. i searched and can't really find nothing, so i come up here hoping to find answers...... thanks in advance, jason |
![]() Join Date: Feb 2007
When you charged the A/C did you have your engine running and the A/C on full Blast? I didn't read the directions the 1st time i charged my A/C and tried it with the engine off. The gauge read the High pressure (as it wasn't circulating). WOrks fine now
If that doesn't work you have to start replacing parts/looking for leaks. |
![]() Join Date: Dec 2006
expansion valve is probably stuck open
happened to mine
yup +1 for expansion valve. Located behind the glove box in the breather case. you need to undo the 2 a/c lines on the firewall side 1st and the box comes out. The Valve wrapped in some gummy tape stuff. I just did mine too in my Nissan 240. My Volvo 240 only needed a recharge
Replace it. It's like $35? I think. Then PM me for a step by step. I just did mine 3 days ago so it's still fresh in my mind.
*****You will have to purge your system before you undo the lines and completely refill it with R134 after***** I did my A/C Dryer while I had my lines off. Another Cheap part. The dryer is super easy to replace though. |
yeah i just pulled the panel out and everything is connected.. the compressor isn't coming on when i have someone push the ac button.. nor is the light.. yet the recirculation light does work
hmmmm. might just be a coincidence. May be a bad bulb in the button and a bad compressor or wiring into the compressor. Check the connector that goes into the compressor with a volt meter with the button pressed and with it off.
