Bushing for Rear Subframe
So I dropped my rear subframe and stripped it of paint in order to repaint it and fix anything that might be rusting (was actually starting to around a couple holes). Before I reinstall it I want to put something better then the stock bushing.
I originally decided to go with aluminum because this is being built as a track car (though street "legal") and I wanted the best possible. After talking it over with one of my friends I think I may go with polyurethane. His theory behind it is that using aluminum without any give in place of bushings would cause a lot of stress on the bolts connected to the frame and could cause warping or other damage. I personally agree with this though if any one else has input I wouldnt mind hearing it. As for what bushings to use... all I could find was these. http://phase2motorsports.stores.yaho...usupibus1.html Ive found other "pineapples" from URAS but from what I could tell they were just spacers and I want full out bushings. |
what the hell?! two questions, is that your rusted ass subframe? if so I wouldnt be looking into new bushings I would be looking for a whole new subframe. and two. what is that orange fire lava looking thing on it?
as for the solid bushings. they are fine and are used by most 240 owners I know (including myself) and there has been no problems at all so far. |
i have solid subframe bushings, solid diff mounts, and all kinds of suspension stuff, and its real clunky out back on the street. but it made the car drive so much better, feels more responsive.
So everyone suggests solid mounts, has anyone has Any problems with them other then the ride being more harsh? |
you might notice alittle more vibration. nothing crazy. mostly on decel. in 3rd and fourth while downshifting. ???hold on, if you just melted your old ones, how are you going to put the aluminum spacers in?
#8 | ||
[ame]http://youtube.com/watch?v=wbUpHjPwLjk[/ame] Besides.. mine were all shot anyway so I needed new ones. |
![]() Join Date: Apr 2005
z32 (energy suspension) poly bushings will fit.
http://www.courtesyparts.com/Merchan...t_Code=7-4102G |
#11 | |
But.. now I still dont know if I should go with aluminum ones or not. haha |
LAID OUT
![]() Join Date: Mar 2004
Just go with the solid aluminum bushings.. SPL sells a nice set. I've never read about any of these supposed problems you and your friend were thinking of...
What are you building your car for? |
As stated, NVH (noise, vibration, harshness) will increase. There's a badass whirring sound emanating out of my drivetrain in second when getting on the throttle. The worst part of the solid bushings that I've experienced is cutting out the old bushing shells (freakin' PITA) and pressing in the solid ones (not as much but still PITA). Otherwise no problems in about 10 months.
#14 | |
#16 | |
#17 | |
![]() Join Date: Jul 2008
I figure i'd bump this thread since im in the market for bushings. Im currently considering the circut sports rear subframe collar kit ($75) over Energy Suspension polyurethane full replacement bushings ($65). The full solid alluminum bushings from SPL and stance are $200+.
If what this guy ^^^^ stated is correct, it really shouldnt matter between solid/poly since its not significantly contributing to suspension performance?
#18 | |
I'd suggest you go with poly bushings I like the feel of the SPL ones but the noise can be annoying at times |
#19 |
![]() Join Date: Feb 2008
I just got energy poly bushings for the rear,I guess I think was phase 2 that shows s14 and s13 use same bushing,just different procedure.If you drive on the street at all poly bushings will work great,my car that I am installing these is going to be used for time attack and street use.Friend of mine has them in his coupe and they very nice,stiff,but not bone jarring like aluminum bushings.Just my .02 cents.
