Old 04-05-2021, 11:17 PM   #1
s13_greg
s13_greg is an unknown quantity at this point
s13 fuel pump not sealing causing fuel leak
Was wondering if anyone else has the same problem as me, my fuel pump seal seems to not be doing its job as soon as i turn on my car fuel begins gushing out. I have tried a couple O-rings from Nissan and new hardware, I am not sure if I am missing something here or what, but was wondering if anyone else has the same issue. I am thinking of putting rtv along with a O-ring to see if that will help. I would appreciate any feedback thanks.
https://www.youtube.com/watch?v=XsgMVQvKdGY
this video is what is happening but much worse.
s13_greg is offline   Reply With Quote
Old 04-07-2021, 08:27 PM   #2
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
What O-ring?
If you put RTV on a rubber part or to try to seal gasoline, you have royally fucked up.
mechanicalmoron is offline   Reply With Quote
Old 04-09-2021, 10:21 AM   #3
jedi03
where is it gushing out of?
Old 04-13-2021, 04:18 PM   #4
s13_greg
Originally Posted by mechanicalmoron View Post
What O-ring?
where the fuel pump bolts onto the tank, just added a video to my post so you can see where exactly
Old 04-18-2021, 04:34 PM   #5
Mikester
Mikester's Avatar
Mikester is a well-known jackass
Does it do it with the feed & return lines connected? Noticed they aren’t connected in the video.
Mikester is offline   Reply With Quote
Old 04-18-2021, 06:28 PM   #6
s13_greg
Originally Posted by Mikester View Post
Does it do it with the feed & return lines connected? Noticed they aren?t connected in the video.
yes it does thats not my video btw just an eample
Old 04-20-2021, 08:17 AM   #7
jedi03
ya that o-ring is a replace each time, i found that out the hard way too...don't strip out those bolts either
fuel pump, s13 240sx
