Old 02-17-2002, 11:01 PM   #1
Omega
Omega is an unknown quantity at this point
taken from <a href="http://www.emergent.com.au/200sx/
3.17" target="_blank">http://www.emergent.com.au/200sx/
3.17</a> What's this about a free boost upgrade?
It's true. &nbsp;You can get a 1-2 psi upgrade by removing the boost restrictor on the top of solenoid valve. &nbsp;It is identified by a white band on the hose which goes from inlet pipe to the solenoid valve. This pipe is at the top of the boost control solenoid. If you don't want to cut the hose, just get a piece of 1/4&quot; fuel hose the same length.
Remember to reconnect all hoses. &nbsp;There is nothing left off or disconnected after this modification. &nbsp;Take the car for a drive and watch your boost gauge. &nbsp;Make sure there is no major increase or decrease in boost level. &nbsp;If there is, stop and recheck your work!
One or two PSI might not sound much, but remember that the export-spec cars run around 10psi (0.7 bar), this is up to twenty percent, or somewhere about 8-10 kilowatts at the rear wheels. &nbsp;Not bad for nothing!
http://www.emergent.com.au/200sx/images/boost_valve_2.jpg
Ok so here is my Q why is it restricted? What are the possible problems that emerge from it not being restricted? What is it actually doing and why is that good sorry I’m totally clueless about this.
Omega is offline   Reply With Quote
Old 02-18-2002, 12:46 AM   #2
Guest
Posts: n/a
too much boost + bad gas = blown engine = warrenty claims = NISSAN doing CYA...
Old 02-18-2002, 02:12 AM   #3
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
Additionally, unless you have an SR in your '95, there's no point <img src="#/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'> 240s are naturally aspirated, no boost, no PSI, no way to gain it by removing components.
misnomer is offline   Reply With Quote
