04-30-2005, 11:20 AM | #1 |
Super TECH questions...lol
If there is a leak in the gasket between the water pump and the engine block.... will the leak cause white smoke to come out of my exhaust?
04-30-2005, 12:25 PM | #3 | |
....so im thinking about draning my coolant and letting my car idle for a very short amount of time and seeing if i still get any smoke. I just hope this shit dosent warp my head |
04-30-2005, 12:47 PM | #4 |
draining your coolant and then letting it run for a short time wont do much, there will still be some in there, even the smallest bit will give you smoke, of course only if that is your problem, I put a little sea foam in there and it smoked for like half hour, so dont think that will work for you, but as far as why its doing this, I dont know sorry.
04-30-2005, 01:07 PM | #5 |
AFC #1
Like a white cloud out your tail pipe or some trace smoke?
If it's a poofy cloud I would bet it's the HG. It's got a crack that you only get blow-by when the system get's upto pressure. I wouldn't run it without water. It's to easy to warp the head. If it's grey/white stream of smoke I would say oil. Which is fun to find. How are your water/oil levels? Wait for the car to cool and check both. If ether are milky, you need a new HG. |
04-30-2005, 06:35 PM | #6 |
My water leve is still low (of corse) and my oil level was un godly high!!! ... so i drained it to the proper level and ran my car for about 10 mins. After 10mins i stomped the gas and got white/bluish smoke. But the smoke is not super blue...its about 97%white smoke and about 3%blue smoke.
