S14.5 Oregon Revamp
Picked up a non complete s14.5 that had been built beat and left out in the elements to Die.. Oh yeah someone genuis had installed a huge sunroof on it which leaked like a mojo and painted (rattle canned ) the top 50% of the car...
[IMG] Cons when i first picked her up. She was over revved with a Down Shift from hell 5th to 2nd and kaboom bye bye top end... not to mention when all of this happened he was on the freeway and the hood flew up ( tommy boy style ) funking up the VIS S15 CF Hood she had a bad boost leak and a T28 that had been starved of the proper oil it needed as they had a jimmy rigged banjo bolt ( of sorts ) out of the block feeding the turbo. Also had compressor surge from the leak being at the Greddy downpipe, sounded like a turkey LOL First thing addressed was the fender and headlight bracket assembly. The front bumper was literally bracketed to the Head light assembly and drooping... Welding time [IMG] Next we addressed new brake pads all around. the fronts came with 6 piston rotoras very nice indeed ! [IMG] Now it was on to fix the horrible " two tone try out " this should do for the time being [IMG] [IMG] At its first Nissan Meet 2 weeks into its new "Relationship" With me lol [IMG] sittin right next to our TT Z32 Swap This is just the beginning of this thread... the build has come very far since... stay tuned for updates Had a HLSD from a S15 in it when purchased took it out for a much better Cusco MZ Baby Installed Included this pic for the hell of it, thought it was kool. hanging out with our Z31 Old S15 Specr T28 Wrapped mani New VS. Old Precisions 550's and Titan Rail - old Greddy Catch Can and Titan Rail brought back to life Update: We are a few days away from starting. new Haltech iun with ignition tach and start signal lines in.. pics of completed LS2 to SR20DET Plug wires, updated dash with new Grip Royal Wheel and a few other randoms [IMG] [IMG] Fuse Block in Magnecor designed LS to SR Coil Wires Wiring Specialties Designed PAtch Loom Harness for Coils to tie into ECU harness Time to finish the Carbon and Metal Dash and get down to business on finalizing Haltech Install Dremel to prep the cut Sparkin Up Test Fit After an 8 hour garage day - chillin with my "Bride" and my Bride lol Helper for interior Sound Deadener REmoval Dry Ice is a our best friend for this job Now were talkin Last edited by richmond82; 01-10-2013 at 12:01 PM.. |
#3 | |
And yeah fixing someone elses bonehead moves sucks royal donkey !
![]() Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert |
looking good
#8 | |
I got to run it for a few months before taking the car down for rebuild
She is for certain,thank you. Got her back from Dyno Shop about 4 weeks ago. Made great power but the dyno shop wasnt very thorough in their Diagnostic and R & R so i can going through it all hose by hose, wire by wire have a drift event on the 4th of next month that i would like to unveil the car in. The local drivers havent seen the car for about a year now
So close to being finished.. need lines made up by Fluid Connectors for the ABS delete and the ASD Hydro install.... intake getting broken stud removed today
Garrett DBB GT3076 to arrive next week... gotta get a downpipe made before the dec 10th tune date /// good problem to have indeed
Just got my laptop back from comp shop. upgraded hard drive for low cost.. yay
now i can run the haltech software manager with no issues. installed this am. stay tuned for fresh air calibration just need to wire in my tps check all grounds then rock and roll on a even better note i just picked up a Garrett GT 3076 plan to install and make up new down pipe before tune session..
#17 |
Just got Temp Coil Bracket done
Will be threading studs into firewall for individual packs soon [IMG]
yes sir it is. good attention to detail !
#19 |
Waiting for the GT 3076 to get here i scored it from a fellow zilvian with low miles and low boost abusing levels
[IMG]
#20 |
Thank you
These guys sponsor my car and do the coatings https://www.facebook.com/pages/Rogue...70968462919037 And the color is from Cerakote Cerakote Coatings
#21 |
Going to be going through all of my grounds and harness one final time after work today. hope to have a permanent bracket solution this week. going to make up 8 studs that are going to be mounted on firewall.
#22 |
Also something i didnt note before is that we are using a top mount fuel rail and top mount injectors and still able to retain the Stock Intake Manifold.... clearance from bottom of intake mani to top of fuel rail is maybe 3 sheets of paper...
lots of machining to make this work but well worth it and definatly a one off
#23 |
Finally got the fittings for the Coolant port on the block and the Port on the Water Neck and the ports on the Turbo. Lines made up and going to picked up this am. Car is 98% start ready. need to call Haltech and ask a few questions about the fresh air calibration and the pre start process.
[IMG]
#24 |
planning to replace the drivers harness this weekend. Talked with Eric at Haltech Tech Support yesterday to get clarity on a few things for calibration and start up.
Ordered up new lines to be made for the coolant feed and return including the feed fitting for the water neck and the return for the block $130 later. got the coolant feed and return lines and fittings figured out today... Slow progress but ill take it [IMG]
![]() Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert Last edited by richmond82; 12-19-2012 at 06:54 PM.. |
#25 |
found more random pics - i hope to get more organized soon
Seam Sealer and Primer Floor [IMG] Interior Prepped for Spray Trunk Done and Drying Interior Shot Back Seat Drying Wide Rears - I know i know they are Rotas Intake Mani MAchined and Power FC Air Intake Temp Tapped also relocated IACV breather also relocated for fuel rail clearance Top Mount RC 750's and Titan Rail Time to Run Fuel Lines Aeromotive FPR mock up time Random Intercooler piping shot Q45 TB Adapter in begining phases Lookin Straight Grizzly TB Comparison Keepin underhood temps low Sorry Ozone - WG Dump pipe Cool Weld pic Still my number one Wrench Before it all startedd Old Power FC DJETRO Setup Wiring Specilaties ECU Harness with all Haltech Sensors integrated hmm picked this up randomly, look at her just begging o be swapped and dropped... lol
#26 |
so to update the build. a pin on the Haltech Map Sensor got destroyed. ordered new one today. I know i know i can go to any junk yard and find a 3 bar GM sensor but i want to ensure i am using all new plugs and connectors on this harness.
I think i am going to start installing the 3076r this week
#27 |
This has been a great weekend !
how she sat before starting Organized and ready to work Pre Wrench High Five needed Turbo Mani Wastegate off Yes i am a Boost Junky Getting Mock up ready
#28 |
Who needs a Rear View mirror anyway ?
My Favorite place to sit and think Intercooler piping will not need to be modded Minor Mod needed to the be made to the Down pipe
#29 |
Finally got coolant feed fittings and line worked out
With Oil Feed line installed have the following left to do before Calibrating Haltech Plat Pro Fix pin on Haltech Map Plug - Finish Brake Lines and Install ASD Hydro - Clean up vacuum lines - Coolant Return line away from Manifold and Steering Rack -Finish Tread fitting for Grenade Shifter - Throttle Cable and Stop Spring
