![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
S14 SE with KA Full Part Out - PBM, Koyo, Mishimoto,
(415) 724-0675 - Call or Text
Located in Rohnert Park, CA VQ35DE SWAP PARTS VQ35 S13 Cold Air Intake - $125 VQ35 ACT Lightweight Flywheel - $300 VQ35 ACT 6 Puck Unsprung Race Clutch (2 events) - $400 SR20 ENGINE S13 SR20 Engine Harness - $125 SR20 Ignitor - $70 S13 Stock Air Intake Tube - $50 S13 SR20 Intake Manifold - $40 SR20 Ignitor - $60 S13 SR20 Clutch Fan - $100 S14 SR20 Stock Cams - $50 SR20 Stock Clutch - $40 SR20 Flywheel - $30 SR20 Alternator Bracket - $40 SR20 Alternator - $50 S13 SR20 Upper Water Neck - $20 KA ENGINE KA Silicone Upper Radiator hose with temp sensor port - $35 KA Intake Filter and maf adapter- $20 KA Engine mount brackets and stock motor mounts - $50 S13 KA24DE Power Steering Lines - $100 S13 KA24DE Intake Tube - $40 S13 KA Coil and Bracket - $30 JZ ENGINE 1JZ-GTE VVTi ETCSi Stock Ignition Coils - $75 1JZ-GTE VVTi ETCSi Stock Exhaust Manifold - $50 BRAKES S13 Stock Rear Brake Calipers - $50 S14 Stock Rear Brake Calipers - $50 S13 Agency power braided brake lines (front and rear) - $80 SUSPENSION S13 **REBUILT** steering rack (one event on it) - $400 S13 Tension Rod Brackets - $100 S13 Lower Tie Bar - $30 S13 Stance gr+ pro coilovers - $800 S13 Suspension Techniques Rear sway bar - $100 S14 Rear Coilovers (unknown brand, not blown) - $80 S14 **BRAND NEW** Suspension Techniques Front Sway Bar (never mounted) - $150 S14 Raceland Coilovers - $200 S14 Tension Rod Brackets - $100 DRIVETRAIN S14 Rear Subframe with Energy Suspension bushings - $350 S14 Open Differential - $150 S14 Axles - $150 S13 Peak Performance Transmission Mount - $35 S13 Front Crossmember - $150 S13 Rear Subframe - $125 S13 Axles - $150 Clutch Master Cylinder - $20 Clutch Slave Cylinder - $20 Braided Clutch Line - $40 EXTERIOR S13 Pig Nose Front Bumper - $100 S13 Bumper Support (pop up headlights) - $60 S13 Power Side Mirrors - $60 S13 Passenger Door (manual windows, no glass, regulator, door panel etc.) - $80 S13 Driver and Passenger Doors (set, power windows, no glass or regulators etc.) - $150 S13 Hatchback Stock Tail Light Set - $50 S13 Hatchback Tail Light Metal Trim Panel - $50 S14 Bumper Mounting Bracket - $50 S14 Trunk - $70 S14 Passenger Door - $80 S14 Zenki Tail Lights - $50 INTERIOR S14 Driver Seat - $100 S13 Ebrake Handle - $40 S13 Ebrake Cables - $50 S13 Power Door Panels - $70 S13 Hatchback Privacy Cover - $70 S13 Power Window Regulators - $120 for the pair (motors included) S13 Climate Control - $50 S13 Passenger Side Window Switch - $40 S13 5 speed shifter trim (no boot) - $60 S13 Black Kick panels - $50 S13 Bottom mount seat bracket - $40 (2) Simpson 5pt Race Harnesses - $90 Driven Suede Steering Wheel - $60 MISCELLANEOUS S13 Engine Bay Wiring Harness with 2 Fuse Boxes - $175 S13 Radiator Brackets - $25 S13 Hood Latch - $35 S13 Hood Latch Cable - $30 S13 TCU Box - $25 S13 Storm Fenders Braces - $25 S14 Hood Hinges - $40 Universal Ebay Blow Off Valve (new) - $25 Aftermarket Remote Oil Filter Mount - $20 RX7 FD OEM Speaker Mounts (driver and passenger) - $50 FD Clock Spring - $175 13B Ignitor - $40 FD Stock Front Lower Control Arms - $175 FD Adjustable Rear Trailing Arms - $100 FD Aftermarket Adjustable Rear Toe Rods - $100 FD Stock Rear Lower Control Arms - $175 FD Stock Rear Upper Control Arms - $175 FD Rear Washer Res and Pump - $40 FD Stock Jack Tools - $40 FD Evap Canister - $25 ![]() ![]() ![]() ![]() ![]() Last edited by DJPimpFlex; 10-10-2019 at 01:04 PM.. |
#16 | |
UGH Really?
![]() Join Date: Aug 2003
Color and pics of the s14 pass door pls
My Review Thread Quote:
#18 | |
UGH Really?
Do you still have the s14 5 speed drive shaft?
