Old 04-26-2013, 01:49 PM   #1
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
Drift Freaq Polyurethane Engine & Trans Mounts! FINAL CLEARANCE SALE!
These are 80 durometer track tested high quality polyurethane engine and trans mounts. There is a link in my sig that will take you to a multi page review. Lots of people here are using my mounts.
[B]The studs do not run straight through the center of these mounts unlike other brands.
You will not get any excessive vibrations from these because of this.
You will get mounts that are better than Nismo and do not rattle your teeth.
A trans mount replacement is recommended as most 240sx stock trans mounts are worn by now. Unless it's been replaced previously. If your shifter moves around a lot your trans mount is probably worn out.
See below for the solution.
Drift Freaq Trans Mounts
The trans mount has exhaust hanger studs!! It also improves your shifting because your transmission no longer moves around under your shift lever like stock. Because of this you get a the effect of having a short shifter without really having one. The shift lever goes straight into its gates quickly and with less effort.
You may experience minor vibrations from the trans mount compared to the feel of a stock trans mount. The trans is responsible for a lot of NVH in our cars hence why Nissan put in the wimpy stock trans mount that let's you shifter wiggle all over. This vibration will diminish as the mounts set in.
I also should point out that the nuts that are provided are Nyloc which means you do not need to torque them down hard. A hand wrench is fine for tightening them. Do not use an air ratchet or impact gun.
This is the latest design with centered studs (that are not connected) in British Racing Green.
Ok Guys this is it we are entering Final days. I am leaving the business. I will be having an End of Business sale with fairly decent discounts.
Which you see below this will be a sale til end of stock.
There will also be no heat shields sold as they are going out of production
$136 shipped for trans mount.
$136 shipped for a set of mounts
$255 shipped for a set of mounts with trans
All sales are final i.e. No returns because you decide you don't want or need them. So please make sure you want/need the item before making your purchase.
my paypal is [email protected]
New Video
Buy my mounts!
Old 04-30-2013, 01:34 AM   #2
DJ-of-E
DJ-of-E's Avatar
DJ-of-E is an unknown quantity at this point
So you finally have a sticky thread. =P
I can attest that these mounts can handle pretty damn over 1000lbs worth of abuse. I know, I did some stupid shit with the engine hoist and forgot to "unbolt" the bottom of the engine mount.
Originally Posted by ocn View Post
its not "DRIFT" tax its a "IDIOT" tax Period!
DJ-of-E is offline   Reply With Quote
Old 05-02-2013, 11:28 PM   #3
denian_cellphone
denian_cellphone's Avatar
denian_cellphone is an unknown quantity at this point
best mounts on the market!
denian_cellphone is offline   Reply With Quote
Old 05-05-2013, 01:57 AM   #4
lalo167
lalo167 is an unknown quantity at this point
Just started my car up for the first time with these on and my motor did not shake one bit during idle!! Put a penny on the valve cover and it was super still. Great mounts!
lalo167 is offline   Reply With Quote
Old 05-05-2013, 02:39 PM   #5
[email protected]
sooorad@aol.com's Avatar
sooorad@aol.com is an unknown quantity at this point
Can locals pick up after the 10th?
sooorad@aol.com is offline   Reply With Quote
Old 05-06-2013, 10:18 AM   #6
drift freaq
yes local pickup will be available after the 10th.
New Video
Buy my mounts!
Old 05-06-2013, 09:37 PM   #7
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
i might have to get me the trans mount. tired of feeling my shifter move.
AsleepAltima is offline   Reply With Quote
Old 05-07-2013, 04:49 PM   #8
zerodameaon
zerodameaon's Avatar
Have been telling myself I need to buy a set of these for a very long time. Finally did and my teeth are going to be very happy to see those other mounts I have go away.
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
Old 05-09-2013, 11:41 AM   #9
AJZax
AJZax is an unknown quantity at this point
These are on my pro-am car. Actually fairly comfortable Even when paired with xcessive solid trans mount (Z32 conversion). I'm VERY happy and I'll be recommending them to everyone in NW region who's looking for mounts
Motor stays very planted, but car doesn't loosen bolts ^_^. It's comfortable. I'm most likely going to buy these for my street/daily s14 car I'll be "building". I'm sure it'd be even smoother with drift freaq trans mount instead of the metal to metal trans mount from xcessive, lol.
I recommend these!
www.ajdrift.com
Mansfield, A - 145
AJZax is offline   Reply With Quote
Old 05-09-2013, 01:53 PM   #10
Rich260z
Rich260z is an unknown quantity at this point
Seriosuly these rock, was using the mounts just on the motor and when started getting parts for a 5 spd swap I knew what tranny mount to get.
Rich260z is offline   Reply With Quote
Old 05-10-2013, 03:41 AM   #11
zerodameaon
They ship today Can't wait.
Old 05-10-2013, 07:46 PM   #12
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
whats the height of these compared to stock or nismo motor mounts. I have a 2jz in mine s13 and my window weld filled mounts have my oil pan sitting level with my subframe.
Car is slammed and oil pan would like some more safety besides my skid plate.
I'm between your mounts and Xcessive mounts.
Thanks
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 05-10-2013, 11:13 PM   #13
drift freaq
Thanks
The height of the mount or how high it makes your engine sit? Nismo mounts raise your engine up about an inch my mounts will drop your engine down about 1/2 inch to 3/4 of inch though the oil pan will not sit below the crossmember. I am not sure how deep the 2j pan runs in comparison to KA or SR pans. If you want a set of mounts that are not going to rattle your teeth then you will want my mounts.
My mounts are right around 2 and 3/4 inches tall.
New Video
Buy my mounts!
Old 05-14-2013, 08:02 PM   #14
zerodameaon
Coming from the temporary(that was not so temporary) fix of Circuit Sports mounts after my stock ones broke, these things are amazing. These feel very nice, very little vibration and they honestly feel way more responsive than the CS mounts. Its also very nice to not have to guess where the transmission is going to be under your car as its bouncing around.
These are great thanks!
Old 05-18-2013, 03:10 PM   #15
ICOMPLAINALOT
ICOMPLAINALOT is an unknown quantity at this point
When will these ship out if I order?
Posted from Zilvia.net App for Android
ICOMPLAINALOT is offline   Reply With Quote
Old 05-18-2013, 03:58 PM   #16
ICOMPLAINALOT
And will they work with my zerolift 1jz s14 swap mounts? The mounts work with the stock engine and Trans mount so I assume it will
Old 05-19-2013, 06:44 AM   #17
Dirtcanhurt089
Dirtcanhurt089's Avatar
Dirtcanhurt089 is an unknown quantity at this point
You have my attention lol ill be ordering a set in the next 2 weeks I need mounts baddd
Sent from my HTC VLE_U using Tapatalk 2
Dirtcanhurt089 is offline   Reply With Quote
Old 05-19-2013, 01:35 PM   #18
drift freaq
They should work fine. As far as shipping goes it is usually pretty fast but i do say allow up to weeks time from ordering for shipping. As far as shipping time itself goes I ship priority mail so you usually see the product in 2-3 days from actual shipment date.
New Video
Buy my mounts!
Old 05-19-2013, 03:02 PM   #19
801nismo104
801nismo104 is an unknown quantity at this point
you should have a memorial day sale discount i bet you will sell alot of sets.
801nismo104 is offline   Reply With Quote
Old 05-19-2013, 09:47 PM   #20
drift freaq
Ya you would like that. Don't expect it to happen now though. You suggested it. LOL
New Video
Buy my mounts!
Old 05-21-2013, 07:17 PM   #21
TwelveAM
TwelveAM's Avatar
Trader Rating: (26)
TwelveAM is an unknown quantity at this point
Feedback Score: 26 reviews
I'll be picking up a tranny mount soon. My car hops all over the place.
Been reading nothing but good reviews on your mounts.
TwelveAM is offline   Reply With Quote
Old 05-25-2013, 11:47 PM   #22
trainwreck 14
trainwreck 14 is an unknown quantity at this point
Why is shipping so expensive on these? I would consider buying if the cost wasn't so disproportional.
trainwreck 14 is offline   Reply With Quote
Old 05-27-2013, 08:47 PM   #23
drift freaq
Perhaps you do not understand the breakdown . Shipping for a set of engine mounts is a flat $16 and for engine and trans is $19 due to the extra weight. The price of the engine mounts is $120 the price of the trans mount is $120 when you buy them together you actually get a $10 discount.
New Video
Buy my mounts!
Old 05-27-2013, 11:22 PM   #24
ICOMPLAINALOT
From the reviews I've been reading the 19 bucks is probably totally worth it
Old 05-28-2013, 02:03 AM   #25
zerodameaon
If this is stopping you, you are really missing out. These are still a deal for the quality you are getting, think of it this way, they cost 249 bucks and you get free shipping.
Old 05-28-2013, 12:00 PM   #26
drift freaq
I might use this in marketing $249 Free shipping! LOL Seriously the shipping cost is less than 10% of the actual purchase price which is no way disproportional.
New Video
Buy my mounts!
Old 05-28-2013, 02:51 PM   #27
Driftwurks
Driftwurks's Avatar
Driftwurks is an unknown quantity at this point
Awesome mounts! Ran them on my S13 and they felt great. Combined with Amsoil transmission fluid, my shifts felt very crisp and fell right into place (none of that wiggling bull on the freeway that you get with stock, worn out mounts).
Originally Posted by jlopez7354 View Post
SoCal is where 240's come to die
Driftwurks is offline   Reply With Quote
Old 05-29-2013, 07:06 PM   #28
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Really... just... REALLY?!?!
So you're saying you would buy them if shipping was $5 cheaper? That doesn't even make sense, talk about a CHEAP ASS...
I guess people's time isn't worth anything to you.
racepar1 is offline   Reply With Quote
Old 05-29-2013, 08:42 PM   #29
ICOMPLAINALOT
Do I just send you the money and leave my address in the notes then you'll ship out?
Old 05-30-2013, 11:07 PM   #30
drift freaq
That is correct. You paypal me and if your address is not in your paypal leave it in a note and I ship them.
New Video
Buy my mounts!
