Old 01-11-2009, 02:07 AM   #1
Jaketenpointo
Jaketenpointo will become famous soon enoughJaketenpointo will become famous soon enoughJaketenpointo will become famous soon enoughJaketenpointo will become famous soon enough
Help: Is this Rod Knock? Video....
I have a KA24De in an S13. I'm worried that my motor is knocking. I'm looking for possible alternatives to my theory (loose exhaust manifold, flywheel, whatever). When driving I only hear the sound with the gas pedal a 1/4 of the down.
Video:
YouTube - Is this rod knock?
Jaketenpointo is offline   Reply With Quote
Old 01-11-2009, 02:28 AM   #2
Future240
Future240's Avatar
If you put this code>>>tE5Bn7TB2Pw in between those>>>>, vid well be in thread
Sounds like it could be knocking, then again I am a newb so who knows
Originally Posted by ThatGuy
Old 01-11-2009, 02:33 AM   #3
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
What ever it is stop fucking running the engine...
Its not good.
Remove valve cova, and look for foul play.. and just keeping diggin.
aint no way you wont find evidence... somethings goin on...
GL.
if you need a new engine lmk. I got a few a got spare blocks you can have free...
I also have a few running swaps. $500
but dig in... you'll learn alot.
Peace brosji
sillyvia13 is offline   Reply With Quote
Old 01-11-2009, 10:29 AM   #4
CrazyKoukiS14
CrazyKoukiS14 is an unknown quantity at this point
Send a message via AIM to CrazyKoukiS14
i had the same prob, im 95% sure that its your timing chain, the tension is probably loose, you have to fix that a.s.a.p, i didnt, my timing chain skipped a couple teeth and then i bent all my valves, that sounds alot like what my engine sounded like, get a new tensioner or a new motor, i recommend a new motor its alot less work then changing the tensioner
CrazyKoukiS14 is offline   Reply With Quote
Old 01-11-2009, 03:39 PM   #5
Jaketenpointo
So follow this Technical Articles: HOW-TO: Fix Your Timing Chain Rattle (sorry for linking to Nico) Its what Google gave me.
