Old 05-31-2012, 08:36 PM   #1
haxoraxe
haxoraxe's Avatar
haxoraxe is an unknown quantity at this point
s13 E-Brake won't lock!
Hey! I wanted to knoq if anyone could give me some advice to make my stock 240sx handbrake to lock the rear wheels... I did adjusted it in the little knob under the handbrake but it still didn't lock... I think that maybe the lines may be bad but since there are not much stock lines, I found these and wanted to know what you guys think about it: Rear Brake Lines for Nissan 240sx 89-98 S13 S14
Also, about the brake pads maybe changing to some that will let me drift which are not project mu d1 spec (maybe ill buy it further on) that is reasonable on price and have nice friction to lock wheels?
Thanks!!
haxoraxe is offline   Reply With Quote
Old 05-31-2012, 08:38 PM   #2
murda-c
murda-c's Avatar
The ebrake is cable operated, it is separate from the hydraulic brake system.
Your cables might be stretched too far to be adjusted tight enough to lock the wheels while moving.
Old 05-31-2012, 08:46 PM   #3
haxoraxe
haxoraxe's Avatar
Hmm, anywhere i can find the 3 cables for the handbrake? front RR and RL?
Old 05-31-2012, 09:10 PM   #4
Perfect Balance
Perfect Balance's Avatar
Perfect Balance is an unknown quantity at this point
A huge factor in this is the brake pads, and how much intitial "bite" they have. Project Mu d1 pads have a lot of this. Keep in mind you can always brake slightly to unload the rear end or turn in a bit when you pull to help it along, but it's still asking a lot of the factory system to lock the rear wheels. Although I've noticed for some reason I have much less trouble locking them on the track than anywhere else, maybe just cause I'm driving a lot harder.
Perfect Balance is offline   Reply With Quote
Old 05-31-2012, 09:22 PM   #5
haxoraxe
haxoraxe's Avatar
but i mean, i adjusted the cable and pulled as hard as i could, pressed the clutch going at a mid speed (40kph) turned a lil bit, pulled ebrake as hard as possibleand nothing happened... just slowed down
Old 06-01-2012, 12:52 AM   #6
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
If i were going to have a stock brake setup i would at least a hydro brake. I love my z32 setup with projec mu shoes though! Never looked back after spending the money.
Since you adjusted it all the way, make sure they arnt now dragging.
Slotted rotors will help expel the gasses created by high temps which increases contact patch of the pads and ebc green stuff pads are cheap and have a quick bite but can fade with lots of heat.
I have a feeling your not going to find a good cheap setup without at least wasting money along the way. Your best off just saving up and getting something good the first time.
4x4le is offline   Reply With Quote
Old 06-01-2012, 12:58 AM   #7
WindyCity
WindyCity's Avatar
WindyCity is a well-known jackass
the only way you will lock up the rears in a straight line is with a hydro e brake. i have a stock e brake and i had the same issue. i tried pulling it to enter and it didnt do a thing. then i bought d1 pads and once they are heated up very good they can lock up going into a corner. also you will find it much easier to lock up the rears once you break them loose. try choku dori into e brake entry. works best for me every time.
WindyCity is offline   Reply With Quote
Old 08-13-2012, 10:41 PM   #8
Nikko
Nikko is an unknown quantity at this point
^^^My stock s13 e-brake locks my back wheels fine in a straight line. it locks up fine at the track and going in a straight line, AND im using shitty duralast brake pads.
Nikko is offline   Reply With Quote
Old 08-14-2012, 03:50 PM   #9
LockOn!
LockOn!'s Avatar
S13 ebrakes are the suck.
I've had cars like Nikkos above where it just works even with the shittest components.
But I've also had to replace all the cables, calipers THEN run projectMUs to the ebrakes to lock.
Its totally effing lame but I must say the PMUs are excellent. I should have just done that in the first place on my car that wasn't cooperating. However they produce SO MUCH BRAKE DUST white wheels turn gunmetal. Lame
Old 08-15-2012, 03:58 AM   #10
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
So u saying u can't drift?
NEED Bolt kits for your car?
Old 08-15-2012, 12:25 PM   #11
haxoraxe
haxoraxe's Avatar
hmm see, i feint to drift, but it seems my cables or pads are shit cause when its raining it will lock, or when im trying to continue the drift it also will lock... so maybe is the pads or ebrake cables, ill try both
Old 08-15-2012, 12:59 PM   #12
Croustibat
Croustibat is an unknown quantity at this point
Guys, may i point out that S13 handbrake setup does NOT use pads, but internal shoes ?
you really dont need handbrake to initiate a drift, just give a sudden turn on the steering immediately followed by a hard tap on the brakes, it will rotate.
Croustibat is offline   Reply With Quote
Old 10-08-2012, 12:43 PM   #13
haxoraxe
haxoraxe's Avatar
normally would the RL and RR cables stretch or the front cable, the one attached to the handbrake?? and which should i get, ebc green stuff or yellow stuff? or which other will you guys recommend??
Old 10-08-2012, 01:05 PM   #14
haxoraxe
haxoraxe's Avatar
accidetnal message
Old 04-28-2015, 01:25 AM   #15
rmc4au
rmc4au is an unknown quantity at this point
bump. not true.
Highskewl's the name, 240's the game
rmc4au is offline   Reply With Quote
Old 04-21-2020, 06:19 AM   #16
NathanBienvenu1997
NathanBienvenu1997 is an unknown quantity at this point
Almost Same trouble
I just bought a 240 and the guy had a drift button on the ebrake, but ive never delt with those. I may have fucked it up and have no clue to fix it, the button it kind of popped out and the ebrake wont even engage anymore lol.
NathanBienvenu1997 is offline   Reply With Quote
Old 04-22-2020, 09:38 PM   #17
seuk
seuk is an unknown quantity at this point
Nathan, just put back the button, it hold with a little bit of pressure. To use it for parking, you have to lift the handbrake lever and pull out the button.
Me neither, brand new pads, new rotors even with gktech extender and ajustement, still no lock. Dont loose your time and money like me, just save up for a hydro ebrake kit. Lock guaranteed
seuk is offline   Reply With Quote
Old 04-22-2020, 10:52 PM   #18
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
It's comforting to be reminded that in the past, most people were also stupid, couldn't drive, and didn't understand physics.
"the more things change, the more they stay the same"
mechanicalmoron is offline   Reply With Quote
Old 04-23-2020, 07:59 PM   #19
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
So happy we brought back this 8 year old thread. For this...
ebrake, handbrake, lock, rear, wheels
