Hey team,
I'm having issues installing my new HIDs (H4 high/low Kaixen kit) Nissansilvia.com -> KAIXEN Xenon Kits OEM 100% KOREAN MADE! HIGH-END $255 RRP$345 - Hardtuned.net The outer squares for the S13 is the H4 bulb, and it sits in a metal bracket/reflector- the bulb is fixed to that by means of a metal clip. Does this bracket/reflector have to come out for the HID burner fitment? I can only assume it does because at first I tried to put the burner assembly in it hits at the very end, and is I don't know, about 1/4 inch too long. But if that is the case, how is the burner attached so it doesn't move around? Do I customise my own bracket for it to sit in? Advice? Need-to-knows? Has anybody actually attempted to install HIDs into this headlight assembly before ( [][] [][] )?? Any help would be appreciated so I can continue doing this. I feel like a bit of a dunce because most people have done the installs quite easily (though on different cars). Cheers. |
#2 | |
![]() Join Date: Mar 2007
Trader Rating: (31)
may need to switch/remove the shield to the basic bulb and Buy some $8 ebay HID conversion shields - IF THose will even fit.Bulb may just need to drop in w.o any shield as the Headlight prob has that built in IIRC. I can't remember my old Brick headlight.....but I've got a set on the way AGAIN for my COupe. I'm gonna use OEM Lexus HID's like I have in my Pop-up H4 lights.They work GREAT.
z-tERty-2 |
