Limp mode/idle issue
I bought a s14 with a s14 sr in it. Mods are fmic, bov blowing to atmosphere, exhaust, isr fpr, isr z32 maf upgraded fuel rail, apexi neo.
When letting the car warm up or sit at idle for a little bit it seems to go into limp mode if im correct. It will hold idle just below 1500 and bounce between 1200-1500, eventually settling down. After that it wont rev past 1500. If i turn car off and wait about 10 seconds then restart its fine but will go back to ot after sitting. Car drives fine if I dont let it idle for to long. When Im at a light or stop, I hold the idle around 2k to prevent it from going into what seems to be limp mode. Previous owner had the timing advanced so i reset it according to frsports how to set cam angle timing. I checked the wiring for the maf and voltage and it reads fine. I even cleaned the maf. I unplugged the maf while running car and doesnt make any difference. I unplugged the tps and no difference. Anyone have any advice or could lead me in the right direction. Ive searched and see threads of the coolant temp sensor or bad cas. I have a coolent temp sensor on the way. Any help would be appreciated |
![]() Join Date: Sep 2005
The best fix for you, is to get a stock mafs (injectors), for the s14sr you have. And relocate the afc to the recycling bin, thats if the injectors are still stock.
You could post the afc neo settings to verify they are correct, but still the best fix is up there. Sent from my LG-H631 using Tapatalk
Ps limp mode is 2500rpm so pull codes and then bin the afc when you get a mafs code.
It set to 2 in 5 out. In car select it has cylinder set to 6. I know sr is 4 but is it set to 6 because of z32 maf? And ignition next to it is set to arrow pointing in the 1 o clock position. I can provide pictures.
Nope wrong 2 is the z mafs 2in5out 5 is the ecu. Fix that cyl selection first.
Its been a while since I've seen an afc on an sr. So i might be wrong. Sent from my LG-H631 using Tapatalk
