03-20-2012, 10:11 AM | #1 |
Funky Wiring Issue --- Help A Noob?
Hey everyone, I'm having what appears to be a dash harness crisis.
Here's the scoop: My wiper blades will not work on the LOW setting with the headlights on. With the headlights off, my wipers work on all settings, no problem. If I turn the wipers on LOW, then turn my headlights on, the wipers stop working. Also, I have no radio. I should, but it's not working. It's an aftermarket one. The previous owner hardwired it in, which is ghetto. My friend, who works on radios and wiring a lot took it out and made an adapter harness. When we plug the harness/radio in, not only does the radio not work, but my wipers act up. They sometimes came on when we pressed the radio power button. Also, with it plugged in, the wipers wipe 3-4 times when the key is turned to accessories. They do not do this when the radio is unplugged. My cluster clock and dome light does not work either. Oh, and the little chime that's supposed to ring with the door open and key in the ignition doesn't ring. We cannot see anything blatantly wrong here, which I figured would be the issue. My friend says the fuses are fine, but I suspect he's wrong. Can anyone point me in the right direction? It's driving me crazy!
1991 240sx Hatch Daily'd! |
03-20-2012, 04:18 PM | #2 |
Someone has some crossed wires. Go look around the harness for places where previous owner tinkered with the harness and start tracing and diagnosing from there.
03-20-2012, 09:48 PM | #3 |
Well I tried that, but I didn't see anything obvious where it had been messed with. I guess I better look closer. Thanks a bunch!
03-27-2012, 06:27 PM | #7 |
I've traced all of this wiring and I can't find anything! I can tell someone else has been back here, but I'm too noobish with wires to figure this out. Where does the radio, wipers, and headlight circuit route?
03-29-2012, 11:18 PM | #8 |
im not in front of the fsm right now but ill give you some tips. open it up to the right wiring diagram for radio and mark where radio wiring starts and the first stop for each wire- relay, fuse, etc. take dash off and follow each wire from where radio harness is to where they need to go making sure nothing is spliced in to anything the diagram doesnt show on the way to said wires destination and no gashes in wires. i believe black or blue in diagrams are L or F or something, youll figure it out. splice oem radio harness(i think amazon sells it) in matching color to color using proper size splices. connect aftermarket radio adapter and test. if that doesnt work then buy a multimeter. oh and to check fuses yourself look at the metal piece through the clear plastic. if its broken in the middle its bad. doesnt sound like a bad fuse problem though
04-02-2012, 12:49 PM | #11 |
How old is your battery and alternator, check and clean your grounds too, try adding another ground and see if the problem still persists, I had loose/ dirty grounds and my car would do things like that too
04-10-2012, 06:37 PM | #14 |
there are 2 grounds off the harness that runs threw the dash one by the fusebox and one by where the ecu is mounted the easy fix would be to run a ground directly from the battery to both of them, or you could just sand it a little bit and see if that works. i had the same problem and i pulled the entire harness to see if any thing was messed up, nothing was but i still had this problem. i ended up getting a new harness and that solved everyting. you got to think with cars almost 20 years old some time shit just goes.
04-12-2012, 10:15 PM | #15 | |
