![]() Join Date: Jun 2009
Looking for all pieces needed to convert my 98 to a manual. I believe 95 and up parts will all work...
maybe an ECU also? |
![]() Join Date: Jun 2002
I wasn't looking to ship it is why I asked where you were located. With me being in South Carolina, it might be a stretch for pickup... Haha!
'92 Miata - BIG Project; '01 A4 1.8T Quattro Super MOD @ 240SX Forums |
#14 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
You're better off getting the master and slave cylinders at Advanced Auto/Auto Zone etc. They have a warrenty, they're cheap, and they're new.
- make your your tranny has position sensors (neutral, reverse, OD (5th), mine didn't so im looking for those right now
- you will need a new driveshaft, any s14 manual one will work but if you have ABS you can use the second half of your auto driveshaft as they are the same. - manual ECU if you want CEL to stay out just adding that as I'm preparing for my 5spd swap in my 95' |
#21 |
I have an S14 clutch pedal in nice shape.
PM me if you're interested
Everything you need to know about the S-Chassis ![]() -- CollectorsEdition.org -- | -- 240sxONE.com -- |
#25 |
You need a abs drive shaft,trans,mt cross memeber,clutch master,slave,hardlies s13 hardlines work to with slight bends,new throw out bearing,clutch pedal,you can shave your brake pedal down,manual ecu, and i d reconmend new clutch,pressure plate,ect. And finding flywheels bolts tend to be a bitch to find but if you can get atleast 1 you can go to ace hardwere and they can help you out since I did my whole conversion.
