![]() Join Date: Dec 2002
![]() Feedback Score: 39 reviews
Re pinning sr20 wiring harness 62->J4
I need a little bit of clarification on repinning a wiring harness for the J4 ecu.
I have pulled the ecu pinouts from the WS website, and marked the ones needed to be relocated. Question is, is the ecu plug the only plug that needs rewired? Thanks for the help!
1997 Nissan 240sx 1991 Nissan 240sx hatch Last edited by silnv; 09-20-2018 at 10:43 PM.. |
Thanks! I’ll look into this. Looks like you were going the opposite direction as I am though.
Was the ecu plug the only plug that needed to be repinned?
1997 Nissan 240sx 1991 Nissan 240sx hatch |
Diagram looks like it will work going either way. The changes are in red, just have to read it. If you only thing you're changing is the ecu, then that should be the only wires you need to move around.
