Old 11-05-2006, 02:57 PM   #1
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
Sr20det transmission swap to KA dohc transmission
After searching for 30minutes using vBulletin's "Awesome" search form i give up
To go from redtop sr20det transmission to using a replacement Dohc KA transmission, is there anything i must to besides swapping the bellhousing of the SR to the KA trans? any needed gaskets that need replaced?
tips, writeups, whatever welcome!
thanks
sepulchral is offline   Reply With Quote
Old 11-05-2006, 07:29 PM   #2
projectRDM
projectRDM's Avatar
None. Little RTV for sealing, that's it.
Old 11-05-2006, 08:19 PM   #3
Slidin240Wayz
Slidin240Wayz's Avatar
Slidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfection
What about the little bolt behind the fork. I know something has to be rearanged, but I don't know what.
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 11-05-2006, 10:33 PM   #4
sepulchral
Carlos
you mean the ball? can you explain or remember what needs to be done?
Old 11-06-2006, 04:28 PM   #5
sepulchral
anyone? ?
Old 11-08-2006, 01:29 AM   #6
blownoffvalve
blownoffvalve is an unknown quantity at this point
i never knew that could be done
blownoffvalve is offline   Reply With Quote
Old 11-08-2006, 01:59 AM   #7
GSXRJJordan
GSXRJJordan's Avatar
wow...
Yeah the bellhousing is easy, and it's always good to throw a new TO bearing in there. If you use the z32 TO bearing (like some clutches say to use), you need a diff fork. Always check the condition of your slave cylinder also, cause its easier to replace the slave first than have the swap not go right, tear it all apart, and realize it was your slave all along. Yeah... been there...
Old 11-08-2006, 09:43 AM   #8
projectRDM
projectRDM's Avatar
I never knew people could be so fucking stupid. Apparently we were both misinformed.
Old 11-09-2006, 09:27 AM   #9
sepulchral
all that i knew, ok, so i dont need anew fork, or anything whatever, im doing it this weekend, ill post some pics
Old 11-09-2006, 08:53 PM   #10
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
I am still scratching my head......
How are you using a KA gear box on a sr bellhousing??????
Both use the werner synchros gear system but both are sooooooo completely different, lengths with bell housing and all as well as the spline itself.
WTF I gotta see this one to believe it........
In all reality just get a freakin SR tranny, you can get them used for under $300 and then get it rebuilt....
Even if it carries an FS5W71C tranny number doesn't at all mean its compatible, unless of course you go through the parts bin of engines like VG,VH,KA,L,LZ, and Z engines with similar bell housings and gear box lengths.
BigVinnie is offline   Reply With Quote
Old 11-09-2006, 09:18 PM   #11
projectRDM
projectRDM's Avatar
You're joking right? This has been covered more times than S14 seats in to S13s.
KA, SR, CA, VG30E, RB20, all use the EXACT SAME TRANSMISSION. Only the bellhousing is different, and in some cases there's a different 5th gear. Direct swap with just a few bolts.
I know for a fact I typed that in large, bold print a minimum of three times this year.
Old 11-09-2006, 09:26 PM   #12
BigVinnie
BigVinnie's Avatar
No not joking just never delt with sr trannys. I also haven't been around the forums for a while or worked on cars for the last year. It's also easier for me to recall what I have worked on. I also know that tranny lengths using FS5W71c's vary in length depending on what vehicle it came out of. Spline length and teeth vary as well, not that it really matters. Thanks for the update...
I believe the 5th gear ratio of the CA transmission is only different.
Z series engines used different variant 1st through 5th gears depending if it was a z20,z22,z24 engine car ,or truck
Old 11-10-2006, 07:00 AM   #13
sepulchral
well hopefully ill have a longer 5th gear for all the 400mile trips to and from wvu to richmond
Old 11-11-2006, 12:05 AM   #14
sunnys14
sunnys14's Avatar
sunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nice
you CAN use a KA tranny on a SR, just swap the front bell housings. ALOT of people say theyre EXACTLY the same, but theyre not. some guy on fresh alloy tested both trannies in each gear and KA and SR tranny had diff max speed at redline in EACH gear.
sunnys14 is offline   Reply With Quote
Old 11-12-2006, 10:06 AM   #15
sepulchral
is ka shorter or longer?
Old 11-12-2006, 10:19 AM   #16
robertftw
robertftw is an unknown quantity at this point
does anyone know gear ratios for the diffrent trannys, and if you can swith them between the gear boxes, or if you can by aftermarket gearsets, if so where? i never hear anyone playing with that kinda stuff for 240's. thanx and sorry if im changing the topic.
robertftw is offline   Reply With Quote
Old 11-12-2006, 10:42 AM   #17
crazyikimasho
crazyikimasho's Avatar
crazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond repute
KA24DE/E
1st- 3.321
2nd- 1.902
3rd- 1.308
4th- 1.000
5th- 0.759
SR20DET (S13/S14)
1st- 3.321
2nd- 1.902
3rd- 1.308
4th- 1.000
5th- 0.838
SR20DET (S15)
1st- 3.626
2nd- 2.20
3rd- 1.541
4th- 1.213
5th- 1.000
6th- 0.767
***PLEASE NOTE*** I am no longer affiliated with West Covina Nissan.
crazyikimasho is offline   Reply With Quote
Old 11-12-2006, 01:58 PM   #18
sepulchral
what is that ratio> will i be at a higher rpm at the same speed in 5th with a KA TRANS? or a lower rpm at the same speed, in comparison to the sr trans
so say im 70mph at 3800rpm in sr
will it be higher speed or lower with KA transmssion at 3800rpm?
Old 11-13-2006, 06:56 AM   #19
sepulchral
Anyone know the answer to this^
Old 11-13-2006, 07:39 AM   #20
S14DB
AFC #1
S14DB's Avatar
Smaller the number the faster you will be going at the same RPM.
Old 11-13-2006, 04:39 PM   #21
sepulchral
im guessing swapping out a 5th gear is hard work
Old 02-04-2007, 07:01 PM   #22
Seikenman
Seikenman's Avatar
Seikenman is an unknown quantity at this point
Originally Posted by justified2.4
SR20DET (S13/S14)
1st- 3.321
2nd- 1.902
3rd- 1.308
4th- 1.000
5th- 0.838
Sorry to bump this, but I was searching about bell housing swaps and this information is wrong. The only Turbo S chassis with a .838 5th gear is the 1st generation S13 with a CA18DET(At least I think so. I get conflicting information on the 5th gear. Some sources say it's .838 and some say it's .759). Here's a chart with all the gear ratios. The KA24 trans (E and DE) have the same ratios as a SR20DET trans
Seikenman is offline   Reply With Quote
Old 02-05-2007, 02:00 AM   #23
King 240
Banned from the Marketplace
King 240's Avatar
King 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-known
I'm glad I found this thread. I just busted my SR20DET transmission this weekend and will be swapping the KA24E transmission with the SR bellhousing.
This help clear up alot of questions I had.
Thought I do still have one, about the diffrent 5th gear ratio, will I be at a high speed at a lower RPM with the KA transmission compared to the SR transmission?
King 240 is offline   Reply With Quote
Old 02-05-2007, 06:31 AM   #24
pr240sx
pr240sx is an unknown quantity at this point
Include 84~89 NON turbo cars
they also have the same 240sx trannies.
Only a bellhousing swap is needed
pr240sx is offline   Reply With Quote
Old 02-05-2007, 07:28 AM   #25
nismosil40zx
nismosil40zx is a well-known jackass
Send a message via AIM to nismosil40zx
I just did the swap to my s13...easiest thing ever. Everything just plugs in and bolts up.
nismosil40zx is offline   Reply With Quote
Old 02-05-2007, 07:35 AM   #26
Inlandsilvia
Inlandsilvia's Avatar
Trader Rating: (25)
Inlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond repute
Feedback Score: 25 reviews
Send a message via AIM to Inlandsilvia
how funny is this...I just did a ka to sr transmission swap last night...total time to put it all together was about 1 hour. it was my first time so...I think next time it will be even faster. six bolts, 1 retaining thingy on the input shaft and bam the housing is off...some RTV and bam it's a sr mission.
Inlandsilvia is offline   Reply With Quote
Old 02-05-2007, 12:53 PM   #27
Seikenman
Seikenman's Avatar
delete delete
Old 02-05-2007, 04:29 PM   #28
King 240
King 240's Avatar
Yeah the transmission I'll be replacing is a SR20DET transmission. I'll be replacing it with a KA transmission.
So I'll be at a lower RPM in 5th but at a higher speed, correct?
Old 02-06-2007, 08:16 PM   #29
Seikenman
Seikenman's Avatar
No. They're the same
Old 02-07-2007, 01:39 PM   #30
King 240
King 240's Avatar
Yeah I found this out after finally finding the gear ratios.
I'll be performing the swap either tonight or tomorrow.
