Z33/VQ35 to SR20 Adapters in stock!
$430 shipped for the adapter plate!
Z33 Transmission to SR20 Adapter! Hey Zilvia! We had a really good response to the original thread and we just got more adapters in! These are the new Version 2 adapters. The new plates have a slight modification which allows a little more clearance with bottom mount turbos. So why a Z33 transmission? Keep reading! The gearing is superior to an SR/KA/Z32 transmission. All of the gears are shorter now so you won't find yourself stuck between 2-3 gear on courses any more. You can now leave it in 3rd gear and rip! Not to mention having a 6 speed transmission that is tough and not made of glass like any SR/KA transmission! This transmission is also significantly stronger. There are local 9 second Z33's that have yet to blow a trans. STOP BREAKING STOCK TRANSMISSIONS! Check out the gear size comparison! You will retain your SR Clutch/Flywheel. You do not need a Z33 clutch. What you need for the swap: -Adapter plate -Transmission mount -Driveshaft -Shortened shifter bracket -Modifying Z33 Bellhousing -Stainless steel clutch line. There are many vendors out there who sell these. Pricing: Just the plate and hardware is $430 shipped Additionally other mods are available in stages depending on what you want to pay for. Bellhousing Machining. Not just any machine shop can do this because of the size of the bellhousing. $80 +ship Shifter modification. You send in your shifter and it gets modified then sent back to you. $125 +ship Transmission crossmember. You can retain the original rubber mount(aftermarket mounts will also work). $100 +ship A video of the first drive. The two-tone s13 in front has the Z33 trans installed. ImportTuner feature on the car we did the prototyping on. Once this is done, you become rad! Contact: http://www.maverick-motorsports.com/collections/all Thanks, George
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all Last edited by maverickmotorsports; 01-11-2017 at 03:38 PM.. |
#2 | |
![]() Join Date: Jul 2008
Ahh no KA-T love?
![]() Quote:
Working on it right now. We should have the R&D done soon and then it will go into testing.
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all |
Nice I want a VQ tranny for my KA-T setup too! Can you guys make a whole kit so that it's just easier? Maybe with a core charge if we don't exchange.
WOW. These are selling fast!
Only 2 left. ![]()
The speedo conversion has already been done by a customer of ours. You will need an ABS diff and a dakota digital conversion box. You can also use the S15 diff and the procedure is the same as putting an S15 transmission in.
#9 | |
![]() Join Date: Jun 2003
Nevermind found a pretty straightforward one on nico. |
#10 | |
We had one of our customers install this kit and do some testing. You guys might know Rob Primo from the northwest. He has some very well built cars and he got a chance to drift with our Z33 kit. Read below to see what he has to say.
We still have a few more left!
The KA adapter is in the works right now. Should be available very soon.
#13 | |
Hey dude looking forward to trying out your plate when it arrives. Have the gearbox sitting on the ground ready to go. this is the car its going in by the way CAR FEATURE>> A RECESSIONARY TALE - Speedhunters ![]() |
![]() Join Date: Jan 2008
I know you got asked a million times in the old thread but any date down the pipeline for an adapter for RBs?
'89 240sx-Track monster in progress '03 Grand Prix GTP-pepped up DD. |
Hey what type of Machining will have to be done to the bell housing on the Z33 transmission? have any photos? also a photo of the transmission bolted to the sr20 would be great!
#16 | ||
*please note, these pictures are from the R&D plate. The plates we sell are refined design.
#17 |
I read on a previous post that you said, The adapter plate cannot be thicker then "3/8". Any thicker and the input shaft on the Z33 wouldn't have made it into the SR pilot bushing." That does not seem to reliable if they are barley mating. I don't know if you mention this before but resurfacing 3/8" off the z33 transmission front flange will still have it engage entirely? send me an email regarding this at [email protected]
The bellhousing is machined to accommodate the adapter. The reason we cannot make the adapter thicker is because we would machine too much off of the bellhousing and cause a weak point in the system. I'd be happy to explain it in depth. Give me a call if you are interested, it's hard to type out why the thickness is what it is.
#19 |
Hi George
the sr20 adapter plate looks good ill take one, can you pm me a price shipped to england please. Im currently running an rb box on a similar adapter plate but the ratios dont suit the sr20 |
#20 |
BUMP!
Just made another run of plates. Keep the orders coming!
#23 |
Here are a few guys using our setup.
Martin Ffrench in his SR20 powered Altezza. This fine gentleman also won RD1 of the Drift Allstars series in the UK. Another guy you might recognize is Walker Wilkerson who is KILLING it in Formula D this season. He's well on his way to rookie of the year. ![]() We have also LOWERED the price to $420 shipped for the adapter plate.
#24 |
Hi george,
I have s14 & g35 6 speed MT. do you know your z33 adapter is fit on g35 transmission? And my other question is for s14 speedo gauge if I put the g35 in my car will my speedo gauge is work or not? if not what can I do to make it work? because I look at your s13 video your speedo is dont work. And my zip numper is 34893 how much is postage price for adapter? Thanks Tomei Sr22DeT Nissan s14 Silvia 200sx | Facebook |
#25 |
Local AZ native Mike Burns wins using a Z33 Adapter!
In his first event with the new Z33/SR20, XDC and Pro-Am competitor took the win at Vegas Drift Pro-Am RD2. Mike fought hard throughout the night and eventually reigned supreme. It's hard to miss his slammed "Team Burst" styled car. Watch for it in upcoming XDC and Pro-Am events! ![]() ![]()
#27 |
Hi George.
quick question about fitting the Z33 gearboxes into S13's whithin the trans tunnel the mount for the cross member is spot welded up and around the tunnel. the box seems to be to big for this area, how have you gone about making it fit? |
#28 |
Anyone able to help me out with this problem? i'm probably just going to start cutting the support up and stiffen it other ways.
anyway i made one of these plates for a RB its behind my 26 thats gong into my ps13. if you want to see more pictures just ask and i kindly pm or post a thread somewhere. im new so just tell me where i should do one. |
#29 |
Im driving a 240sx sr20det and working on a g35 transmission swap. I allready purchased the convertion kit that is mentioned in this forum.The problem i have is that g35 doents have the speed sensor so when i cant get the signal from the transmission do i get it through the ABS system? how can i get my speed meter work when i do the swap?
p.s. im using Aem Stand Alone ECU |
#30 | |
