No more nissan.
![]() Join Date: Jan 2003
Side Mount Inter Coolers
Lets talk about them.
say for example, you have ~270whp, but you don't want a front mount intercooler. BECAUSE YOU DONT WANT ONE! Don't ask questions. S15 SMIC is kinda beefy, so is ARC. How are they gonna hold up to that? Where could you get these intercoolers for cheap?
![]() Join Date: Aug 2005
Trader Rating: (60)
![]() Feedback Score: 60 reviews
Just realize that a sidemount at 270whp will get heatsoaked really easily with hard driving. Even though s15 or ARC are a little thicker, there still isnt that much surface area to dissipate the heat.
For whatever reason you want to go with a sidemount, you will see a good 20-25 hp increase with a front mount over a sidemount. A sidemount is fine but its just not efficient. As for pricing to give you an idea, I got a ARC sidemount with my front clip and sold it on ebay for 230 dollars on ebay when I went to a front mount. I included the core, all the piping and the brackets. |
As long as the SMIC is receiving a good amount of air it will work almost as well as a FMIC. I say that because obviously with a front mount typically you have a much larger surface area that can be cooled. With the SMIC your sacraficing the size of the intercooler's surface area.
cheap intercoolers? check ebay. |
#4 | |
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
last time i checked heat exchanger equations, surface area is multiplied!
Make sure you use the ducting for the SMIC. Most people do not use any ducting for FMIC so you may be able to get slightly closer to most FMIC performances.. just making an educated guess.
HouseBuyers365.com Quote:
why dont you want a front mount??
LOLOLOL jkjkjkjkj what you can do is fabricate a duct that goes to the smic just like in supra and soarers... dont really know anything about the setups on silvias.
1994 SC300 5spd 1 of 227, 2jzgte, r154 5 speed.
No more nissan.
Yah, it'll be properly ducted.
I dont care about the powerloss though either. I dont want a front mount because I don't have to explain myself. EAT ME ![]()
![]() Join Date: Feb 2006
iirc the supra stock sidemount is good to 400whp. allot of dsm guys run them as an upgrade sidemount. i have never herd of any 240s/sr/rb runnig one wbut would like 2 see it.
Mouth of the South There are a few mailboxes that have been looking at me the wrong way, lately. Nothing goes unchecked.
you could, besides ARC and s15... get a small ebay or no-brand intercooler and make your own custom piping for it... if they are properly ducted and its decently sized you will get a nice cooling...
are you avoiding front mount because of the piping? just in case it's that you can get those really thin front mounts that you dont have to cut bumper that much, get one with the inlet/outlet on the same side and use side mount intercooler piping(arc had a design like this...) Ps. forgot to say, some companies make aftermarket sidemounts for 300zx and eclipse... check those out... |
No more nissan.
I'm avoiding Front mount because I don't want a cooler up in the front, because I like the OE piping, and.. I don't want a front mount.
![]() Join Date: Mar 2008
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
So then why don't you just do a top mount or mount it just in front of the radiator ???
The stock side mount has miles and miles of piping........= lag |
You got a pm my friend
#16 | |
No more nissan.
front mounts go down through battery trays, around front braces to in front of the radiator, all the way back around the other side, and up through in front of the fenderwell again.. F-that. And I said I wanted a fucking SIDE MOUNT. SHUTUP. haha, which is why I said don't ask questions. and the piping on stock is tiny. that wont be laggy. specially not with a t28 on a 2.4 liter. It'll be ducted!! LEGIT. custom fibreglass shrouding.
Considering s15's make what 260 stock. The sidemount should be sufficient for a higher comp 2.4 thats flowing the same amount of air reaching your target hp number
#19 |
Custom make it, 4" custome made to fit stock piping. stock LxHx4" core should be a decent setup if properly ducted plus you could also rig a water sprayer application on the SMIC.
WAter sprayer is cheap and easy custome making the core would be a few bucks
Drift cars have no business being practical, fast, or functional. |
#21 |
Come on, this isn't Gran Turismo.
#23 |
Side mounts are for homos and lames.
And Evan. Get an S15 one man, it'll be fine for your lil setup - pretty cheap, low pro, etc.
#25 |
No more nissan.
I found an s15 core for pretty cheap.
I'll do a mist-sprayer setup on it.. Less I can find a Supra one for a better deal than the s15. Doubt it though.
#26 |
This is my favorite setup, especially when you're not pumping out huge power - you get the efficiency of a small core with the cooling of a frontmount and the "I'm not turbo" look of a side mount.
I was going to go mid-mount on my S14, but ran out of funds for new IC stuff. Plus my aero looks awesome with the front mount ![]()
#27 |
![]() Join Date: Oct 2004
You wont need a fmic if you get this.
DevilsOwn alcohol water injection- methanol AEM - Water/Methanol Injection Kit with 1-Gallon Tank You run 50/50 water and meth, you get the best of both worlds. Running water will help lower EGT's. Running meth will increase octane rating and if you have the right EMS you can advance timing more and run more boost with a larger saftey margin.
#28 |
No more nissan.
SSSIIDDEEMMOUNNTT, you know.. one that goes on the SIDE.
and I'm not doing meth injections. People die from meth. haha I'm gonna run a WATER sprayer to spray the IC at track days. A simple little water tank and pump system. Garden drip system status. And Jeff, you need a big sexy FMIC so nobody looks at your cowplower. ![]() You'll jock my setup when its finished. TRUST.
#29 | ||
#30 | |
Trader Rating: (18)
If you read my post I said a top mount or in front of the radiator up high !!! which has way less piping then any side mount !!!! Obvsouly you haven't done your research |
