![]() Join Date: Jun 2011
sr20 pump gas pedal to start
Hey yall i searched and nothin really whats happenin to me. I got a redtop sr and the problem i know of right now is my intake mani has a small crack on the middle of the flange that connects to the head. That resulted in a blown gasket also my iacv had a ripped gasket i fixed with some gasket maker though when i was threading on the screw the back piece of the flange broke off....while hand tightening lol. I got a new intake mani on the way so not a problem. I may be answering my own question but anyone had something like this happen? it only starts when u pump the gas pedal then once it warms up it drives fine. any input
zilvia.net/f/cars-sale/517359-95-240sx-sr20-swap-uras-greddy-apexi-ect.html |
hey still need some input someone has to of had this issue happen before swapped out manis and it fixed a few issues but not the starting issue i still have to pump the gas peddal to start
![]() Join Date: Nov 2010
is ur iacv still busted? fix that and u will be able to start easier, you dont want any vac leaks it wreaks havoc on SRs
iacv is good when i said new mani it included everything could it possibly be one screw from mani to block is partially stripped but no leaks from there and i dont think i got any leaks anywhere else. I gotta test the rest of it but no irradic idle or anythin just gotta pump gas to start
o no dice so far starts up perfectly fine if im pumpin the peddal anyone thinkin tps or something I dont see it being my cas but you never know im just lookin for some direction here
Check start signal fuse in fuse box in the car. Also check the orange wire i think going to the ecu. If the fuse is bad or a short in that wire it will be hard to start but run fine after. Had similar problem on my blacktop s13.
funny I just messed with my tps and it fired right up tomorrow if the problem persists ill go ahead and check that out
reset tps and timing then reseated intake mani fixed the problem
