![]() Join Date: Sep 2010
Hey zilvians,
I'm researching what I'm gonna need financially to starr my sr build and wanted to get some info on what I should be expecting to spend. Hers what I want: Sr notchtop five speed, four inch piping frontmount, built head, tuned ecu, 555 injectors, s15 t28, koyo rad. Pretty much 400 reliable power to the wheels Any info will help. Thanks sexys! |
![]() Join Date: Jul 2008
Trader Rating: (32)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 32 reviews
that setup will get you 320 MAX.
1) small ass turbo 2) 555cc injectors are good to 350whp i believe get bigger injectors and a bigger turbo (2871R) |
Man w/ CTSV & a Car Seat
Shit, this is a dumb generic ass question. There's so much different ways of getting there and too many variables to pull a magical number out of somebody's ass. Are you doing the work or you having a shop do it? Considering you have absolutely no fucking clue since you made a thread like this, go to a shop and have them give you a damn estimate. For as much shit you want, it aint gonna be cheap...Id throw in some $12k to do it all in one fell swoop.
#4 | |
Or, you could buy my car
#/f/cars-sale/427482...t-sr20det.html Fully Built Sil80 with Forged Fully Built SR20 with 1500 miles on it. Which has everything you're looking for, and an engine capable of making 500 HP safely(results may vary), and pay half of the price. I will give you a breakdown of basically what it cost me: Bought the fully built shortblock, rods, pistons etc for 1200. Found out that the machine shop that the guy I bought it from was shit, and had no clue what they were doing. Built Short Block: 1200 (Mahle Forged Pistons, Eagle Rods, ACL bearings) Rebore/Hone/blueprint: 150 Piston Rings 80 Correct Size ACL Bearings: 115 Oil Pump: 150 Block Decked with Oil Pump: 75 Micropolish Crank: 35 Shortblock Assembly: 300 Total: 2105 I also bought a semi-built head: for 300, Which was a steal and had: BC Ti Springs BC Ti Retainers Supertech valve stem seals Recondition(Port polish etc/ install Supertech valve stem seals etc: 280 ARP Headstuds: 130 Cosworth Headgasket 150 New S14 Waterpump: 50 Timing chain kit: 175 Total engine assembly: 250 Total 1635 ACT Sprung HD Clutch to hold power: 500 Flywhell Resurfacing: 35 550cc Injectors: 300 S15 turbo: 500? Ecu Tune: 400 Turbo Lines/Reclocking adapters: 150 1200 for tune/injectors etc? About 5000 bucks so far...
![]() Join Date: Sep 2011
I got an s14 sr I got alotta shit in it
I'll start top to bottom Ngk level 7 plugs New oem lifters New oem rocker arms Hks ras Hks step 1 256 cams New cam sprocket Arp head n main studs 3 angle valve job New valve seals Port n polish Gasket match Decked the head Apexi multilayer head gasket New timing chain kit (chain guides tensioner sprockets gaskets) New oil pump New oil pump drive gear Nismo 65C thermostat Wiseco 86mm piston heads Eagle H-beam rods Acl main n rod bearings Full gasket kit Greddy oil pan Tomei expreme header New O2 sensor New oil pressure sensor Tomei turbo elbow Oem filter Arp fly wheel bolts Atc 6 puck clutch Nismo motor n tranny mount Braided turbo lines Greddy magnetic oil plug I think that's all of it I might have missed a few things but I'm right at about $6500 more or less it's expensive shit man I was debating ls1 swap but that's close to $12000 so I rebuilt my s14 hope this gives u a better idea about how much it costs |
Kamina sam pm me bro we will talk. And for the others who have gave me good info pm me and we can talk. For the few that decideto be vulger and rude here is a reality check. This is a nissan forum not a honda page so get rid of the additude. I do have a vast knowelge base on nissans and know many of shop owners in the souther california area. I simply was seeking numbers so I could get an idea of what I would be spending on my build. That being said keep your negative comments to youself and get a life. Zilvia is intended to be a conglomeration of nissan fanatics who share knowledge and know how to others who seek that. Remember that shit talkers. Other than that have a good day. Thanks again to those who helped. Greatly appreciated.
#9 | |
You are supposed to search, as there are lots of answers on this site already but it in no way gives someone the right to be an asshole. Please search more because again there are lots of answers on this site. Here are a few places you might want to look at. They have a lot of information and other people's setups you can base yours off of and get ideas. #/f/chat/297481-smal...w-threads.html #/f/chat/372559-turb...no-charts.html #/f/chat/361235-how-...-240-have.html |
#10 | |
![]() Join Date: May 2009
![]() Feedback Score: 20 reviews
It was a pretty broad question, you should have just asked me! Craze is pretty good with 240s, you don't know him, so don't go assuming things. And kamina! His car is legit I've ridden in it, I want his type x valences! Anyway, your looking at like 4-6k for clean good every day 400hp including the swap and all the stuff you should replace Edit, Actually, the wing thats on your car right now came from kamina lol Last edited by Tantwoforty; 01-16-2012 at 04:56 PM.. |
#12 | |
But you know what, I'll be fucking nice...you want 400hp, start with a damn turbo to get you there. You want response, run a GT2871R .86, should be enough to get you close enough to it. You want more power, up it up to a GT3071R with a decent top mount setup. Run some 740cc Nismo injectors or SARD 850s. Throw in a stand alone ECU setup (Power FC, AEM or go big boy with Haltech) and thats a good start... I got $5 this shit will get locked soon... |
#13 | |
![]() Join Date: Jun 2003
Trader Rating: (129)
stock sr 200 shot of nos. there. 300hp for cheap. also, why are you asking these questions on an internet forum??? 4" intercooler piping? if you know what parts you are looking for, why not contact the people who SELL those parts. check with FRsport, phase2, etc. this is just ANOTHER thread that doesn't need to be here, you could easily have answered all your questions by doing your own research. ![]() |
I like everyone being assholes, makes it fun to troll around. Nothing wrong with asking questions, but you gotta have thick skin on here. And +1 on research, I always search and dig before i ask a question. That or i use at least 8 big words in my thread so people think im smart. Good luck on your power goals!
91 TTZ |
#15 | ||
