#31 |
Do you happen to make any that fit a 3" inlet on the compessor housing?
So 3" all the way to fit Z32 maf?
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’ Jeremy Clarkson on Automatics |
#32 |
Sent you a PM!
I need just the straight intake pipe with the fitting for vacuum hose from the T25 Kit.... Price shipped to 11553? Thanks
http://www.leg1t.com |
#34 | ||
if anyone has upgraded from a t25 to a t28 with a z32 MAF & a reclocking kit and you are using the OEM inlet adapter from the S13 like moon ill, you will need us to weld a s13 crankcase breather fitting on the 3" tube which is an extra charge, so please notify us of the special circumstance before you order and we'll take care of you.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
