Old 06-23-2010, 01:10 PM   #1
conrad_s13.5
conrad_s13.5's Avatar
SR20DET High Flow Oil Pump
Did some searching,. cant see of any aftermarket support on this, I read somewhere that you could hack together a higher flow oil pump with some GTiR parts.
did see anything on here, but figured that someone ran into this or has more knowledge then me on this.
school me!
cONtRol FReAkS
Old 06-23-2010, 01:49 PM   #2
Prok0
Prok0 will become famous soon enoughProk0 will become famous soon enoughProk0 will become famous soon enough
Send a message via AIM to Prok0
Dont believe there really are any aftermarket oil pumps for SR's unless you go to a full dry sump or something..
You could shim the stock pump though.
Prok0 is offline   Reply With Quote
Old 06-24-2010, 09:52 PM   #3
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
What's your reasoning behind more oil pressure? Stock pumps provide a substantial amount, IIRC only the VE pumps produce more
Old 06-24-2010, 11:16 PM   #4
Homer_Simpson
Homer_Simpson's Avatar
Homer_Simpson is on the path to ruinHomer_Simpson is on the path to ruinHomer_Simpson is on the path to ruin
There's a guy in Australia that stuck a GTiR front cover on to his RWD SR and made it work. He did some convoluted stuff to get everything done including messing with the oil pick up.
At the end he got it to work but one of the top bolt hole that is screwed into the head is not usable (if you put the two front cover side by side then you will see), as well as the pin for timing is at different place.
The S13 SR has the thinnest oil-pump gears and like Cody said, the GTiR has the thickest IIRC even thicker than the VE pump gears.
If I were to go with the GTiR path, I would just cut and weld the second bolt hole making it usable to prevent leaks.
Homer_Simpson is offline   Reply With Quote
Old 06-25-2010, 09:20 AM   #5
codyace
codyace's Avatar
Trader Rating: (58)
I did forget about the GTiR ones as well...but even still, it takes an extended amount of work to make it work, and to make it work on a street car may be a bit overkill IMO
Old 06-25-2010, 06:43 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
There are aftermarket options out there but they cost a buttload of loot. I know JUN was one of those companies, just not sure if they still are.
CLICK HERE!!!
Old 06-25-2010, 07:17 PM   #7
D.Adams
D.Adams's Avatar
this might be your best bet.
High Flowing Oil Pump for SR20DET - Hardtuned.net
JUN Auto made one and it was $700 plus for it.
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
Owner of NVS Fabrications
Old 06-25-2010, 08:48 PM   #8
Homer_Simpson
That's the guy I was talking about.
Old 06-25-2010, 11:30 PM   #9
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
JWT has a rebuilt oil pump with more flow.
rebornS14 is offline   Reply With Quote
Old 06-25-2010, 11:48 PM   #10
Homer_Simpson
Are you sure that it is for the RWD SR?
The FWD SR guys mentioned that the high flow oil pump from JWT is basically a GTiR pump with all the parts necessary to be fitted on to the FWD SR.
Old 06-27-2010, 07:04 PM   #11
codyace
codyace's Avatar
Trader Rating: (58)
The JWT one is for the FWD cars for sure. The DE pumps IIRC actually flow 'the least' of all the Nissan pumps, but by all means there are countless users on stock pumps without issue as well.
Again, a high flow oil pump (to me) is a bit overkill this side of a race car
