Steering Angle Spacers! $45 shipped!
IN STOCK AND FREE SHIPPING!
These spacers easily add more angle to your steering! Check out the pictures below. - Use on S13, S14, S15, Z32, R32, R33, Z33, G35, and a ton more Nissans. - Machined from 4130 Chromoly - Adds ~14º to your steering! - CNC machined by a medical/aerospace certified machine shop - Easy install. Re-center the rack after you install these. Price: $45 Shipped. You only need 1 per car. INSTALL ON PASSENGER SIDE. Use 2 with knuckles for even more angle. INSTALLED PICS! I took some pics of my daily driver. ONLY ONE SPACER INSTALLED. S13, stock suspension, stock steering. BEFORE: 37º of steering angle stock. AFTER: 51º of steering angle after adding only ONE spacer! Added 14º of steering lock. You can grind down the steering stops and get even more. Place your orders here. Steering Angle Rack Spacers - Maverick Motorsports
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all |
Will this spacer work with Tein Inner & Outer Tie Rods on a s13? A friend of my told me that it won't because those are longer than stock and I won't be able to line up my wheels.
Thanks for the help on advance. |
